QUESTION SHAVING TOP OF PCT CTR PISTONS FOR B18C1 BLOCK?
Old Oct 28, 2011 | 02:07 PM
PLATANOLOCO's Avatar
Icon2 QUESTION SHAVING TOP OF PCT CTR PISTONS FOR B18C1 BLOCK?
I WAS WONDERING IF I COULD TAKE MY CTRS TO A MACHINE SHOP AND SHAVING THE DOME A LITTLE BIT TO YEILD A 12.2:1 COMPRESSION GSR BOTTOM WITH B16 HEAD?
THE GUY SAID HEAD USE THE SAME MACHINE THAT SHAVES THE HEAD AND WOULD WEIGH AND BALANCE PISTONS AFTER
Old Oct 28, 2011 | 02:30 PM
sebTeggy's Avatar
Default Re: QUESTION SHAVING TOP OF PCT CTR PISTONS FOR B18C1 BLOCK?
Wanna drop the compression? Get a thicker headgasket
This is a pretty specific question... Not a lot of people run poor-man type R builds with PCT pistons
Old Oct 28, 2011 | 03:20 PM
doood's Avatar
been there done that
get p30's instead. much safer compression without the massive dome.
Old Oct 28, 2011 | 03:23 PM
TunerN00b's Avatar
First of all
Second, shaving cast pistons sounds like a great alternative to buying the correct parts to achieve what you want. Go for it. What could possibly go wrong?
Third, why isn't this in either the tech/misc, all motor, or even hybrid forums instead of here?
Old Oct 28, 2011 | 03:50 PM
EnjoyTheRideDC2's Avatar
Originally Posted by TunerN00b
Second, shaving cast pistons sounds like a great alternative to buying the correct parts to achieve what you want. Go for it. What could possibly go wrong? LOL
Third, why isn't this in either the tech/misc, all motor, or even hybrid forums instead of here? Probably because he has an Integra. Judging by his type of question, i'd excuse him.
Old Oct 28, 2011 | 05:50 PM
SORRY ABOout THE CAPS I DiDNT KNOTICE....
my little brother is the one doing it but hes on the broke side he bought the block with the pistons....
the macine shop said $45 for it all machining and blancing he will be running on e85 daily have station 3miles from house
the reason i asked about the shaving is becouse the guy at the machine shop offered us this option when we were picking up the head from being resurfaced.....
it thought the same thing as you guys why not just get a thicker head gasket but he mentioned that this way you can reduce the weight of the ctr piston at the same time while reducing the weight.....
Old Oct 28, 2011 | 05:58 PM
Hidenplanvew's Avatar
you have to also think your going to be making the piston top thickness thinner and more of a chance to blow a hole in the piston if something were to happen.
Old Oct 28, 2011 | 06:43 PM
damn you got a good point... i didnt think of that.... they are nippon pistons if it helps any...
lol im not goindg to lie i actually assumed that the pistons were like the pr3 but with extra matirial on the top...
Old Oct 29, 2011 | 11:03 AM
Quik Chris's Avatar
I wouldn't do it with cast pistons. They were cast with that thickness for a reason, once you start removing material you're playing with fire. Get a thicker head gasket or tune it for that compression and gas you want to use.
Old Oct 29, 2011 | 03:23 PM
tam4511's Avatar
a cast piston is a cast piston, look for some itr pistons or maybe just go forged.
Old Oct 30, 2011 | 07:26 AM
Local's Avatar
Sounds shoddy at best
Eg6DR
Mar 6, 2008 07:27 AM
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
Jmorin
12
May 29, 2004 02:30 PM
flashgsr
Sep 15, 2002 08:42 AM
junjun
10
Sep 12, 2001 06:48 AM
