what top hats will work for my F&F TYPE 1S
Old Oct 27, 2011 | 06:56 AM
ewok1's Avatar
Default what top hats will work for my F&F TYPE 1S
lookin to buy sum top hats but don't know wich ones are compatable with type 1s. .If any one has type 1s and are rockin top hats lmk wich ones ur using thanks
Old Oct 27, 2011 | 07:58 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: what top hats will work for my F&F TYPE 1S
Stock ones should work fine... I am curious why in the world do you even need them? Do you not realize the body drops down in the sleeve? That's the whole purpose of full coil-overs... to stay away from the ghetto tricks and do it right.
Old Oct 27, 2011 | 07:12 PM
ewok1's Avatar
umm, the f&f type 1s are full coilovers. I judt don't want to move the coils any lower than the specific limit. .If i put the extended top hats it will allow a lower drop without any movement of the coils and blowing the struts.,this is from what i researching. still cant get an exact answer on what type of top hats they are using for an ef.
Old Oct 27, 2011 | 07:24 PM
Tyson's Avatar
you researched wrong.
Old Oct 27, 2011 | 07:50 PM
DA is best's Avatar
Ff1s will work just fine without tophats, slammed or not
Old Oct 27, 2011 | 07:57 PM
ewok1's Avatar
so there is no need for extended top hats?
Old Oct 27, 2011 | 08:02 PM
DA is best's Avatar
Those full coilovers are made for lowered cars, if you were to get say ground control coilovers and say tokico struts then yes I say get tops hats cuz those tokicos arnt made for cars lowered 3"+......the functions are
Old Oct 27, 2011 | 09:19 PM
Tyson's Avatar
Top hats work by allowing the shock body and bumpstop to enter inside the top hat itself, this allows the bumstop to do its thing and prevent the piston from bottoming out internally.
Aftermarket full coilover bodies won't fit inside an extended top hat. This negates the benefit of the top hat. You might as well just remove the bumpstop entirely.
Old Oct 27, 2011 | 09:28 PM
ewok1's Avatar
thanks for the info!
Old Oct 28, 2011 | 03:47 AM
DO IT ON ALL FOURS
I should have added I have those specific coil-overs on two of my vehicles. Personally they suck for a daily driver. I have blown at least one shock a year and I am not some kid beating my crap up and trying to it every pot hole I can find. Replacements are $75-$100 depending on what vehicle it's for.
Old Oct 28, 2011 | 04:35 AM
ewok1's Avatar
thanks again
Del1995Sol
Suspension & Brakes
Jul 5, 2012 01:47 PM
ANNiHiLATORS
Suspension & Brakes
Apr 7, 2012 01:52 AM
RickR
Suspension & Brakes
May 21, 2010 06:12 AM
dragonfly2k3
Suspension & Brakes
Aug 26, 2008 12:03 PM
