e-brake not working. cables move, brakes work
Old Oct 27, 2011 | 04:25 AM
ali954's Avatar
Default e-brake not working. cables move, brakes work
A while ago, i did the rear disc on my 94 del sol vtec. new pads and rotors and i cleaned out and re-lubed sliding pins. i remember when putting the e-brake cables back on for one side or maybe both, that i had to turn the mechanism to line up the hole on the cable correctly. when doing this it slipped or gave way and made a loud pop and then i was able to line it up correctly. brakes work fine back there and make good pad rotor contact. the e-brake cables move in cabin and on calipers but e-brake does not do anything at all. btw one side is a swapped out for a different caliper if it matters.
hope i dont have to get new calipers but if i do rsx/ep3 here i come.
Old Oct 27, 2011 | 07:45 AM
sde780's Avatar
Default Re: e-brake not working. cables move, brakes work
Have you checked where the Ebrake handle connects to the cables, there's an adjuster there to change the slack.
Old Oct 27, 2011 | 07:59 AM
ali954's Avatar
yes ive tried it all the way up and even added spacers for it to pull more and nothing, but i can see the lever on the calipers move.
civicseth
11
Feb 8, 2007 10:00 AM
JDM_Andrew
Sep 7, 2006 07:51 PM
wade
Feb 1, 2006 11:17 AM
pennies_hatchie
18
Jun 9, 2005 05:28 PM
pennies_hatchie
13
May 30, 2005 07:46 PM
