bad vtec wiring need Help
Old Oct 26, 2011 | 10:37 PM
momodc221's Avatar
Icon3 bad vtec wiring need Help
i have a 95 gsr with a b18c the wiring for the vtec is messed up bad n i cnt tell if its obd1 or obd2 i just need help will post pic tomorrow
Old Oct 26, 2011 | 11:02 PM
mouab18c1's Avatar
Default Re: bad vtec wiring need Help
How is the wiring messed up? If it's a gsr then you shouldn't even need to wire it in.
Old Oct 26, 2011 | 11:15 PM
momodc221's Avatar
Icon2 Re: bad vtec wiring need Help
well i bought the car off some one and i guess they mikeymoused the wiring for the vtec cause its obd1 to the ecu pr3 but i think the connectors to the sensors are obd2 but i will take pic n show tomorrow
Old Oct 27, 2011 | 12:02 AM
mouab18c1's Avatar
If the car itself is a GSR model, the Vtec wiring would already be there. The only time you would have to wire in vtec is if the car model is an ls, rs,etc...
Also what are you referring to as obd2? The 95 model is obd1.
Old Oct 27, 2011 | 12:50 PM
momodc221's Avatar
i was confused y they cut the wires i bought the car like this n i need a little help i dnt mess wit electrical stuff had a bad experience as a kid.
Old Oct 27, 2011 | 12:51 PM
momodc221's Avatar
Old Oct 27, 2011 | 02:03 PM
mouab18c1's Avatar
Take a picture
Old Oct 27, 2011 | 02:40 PM
momodc221's Avatar
Old Oct 27, 2011 | 02:43 PM
momodc221's Avatar
Old Oct 27, 2011 | 02:47 PM
momodc221's Avatar
see i dnt knw. do i need new wires cause the vtec dosent work. and i think the connectors for it r obd1. so should i get the vtec subharness kit or do something else.
Old Oct 27, 2011 | 04:34 PM
Freddyboom's Avatar
Same thing happened to me I had to get the obd1 wire my buddy plugged it in .
Old Oct 27, 2011 | 04:57 PM
fcm's Avatar
fcm
Old Fart
Pics are not working. 94
Old Oct 27, 2011 | 05:04 PM
speedooo's Avatar
You don't even need plugs. The solenoid can be wired straight to the ecu and on the pressure switch you can ground one wire right on the valve cover and wire the other straight to the ecu. The type of plug makes absolutely no difference in anything.
Old Oct 27, 2011 | 06:19 PM
momodc221's Avatar
just cant figure out why the vtec wont work. but i see wht your sayn thanks for the help
Old Oct 27, 2011 | 10:56 PM
mouab18c1's Avatar
You're really confusing me.
Old Oct 28, 2011 | 08:57 AM
momodc221's Avatar
sorry ill try to take better pics
Old Oct 28, 2011 | 01:40 PM
Hidenplanvew's Avatar
Isnt pr3 obd0? How do you know vtec isnt working? Gsr shoud be p72 or chiped obd1 ecu
Old Oct 28, 2011 | 09:22 PM
momodc221's Avatar
its hooked up to my obd1 harness. but im gonna get a p72 ecu to see if tht my be it too. but tht pr3 is for a old school b16 sir i think. im gonna sell it anyway after i get this p72. i think its either the wiring or the ecu. so im gonna fix both n let u knw how it goes.
Old Oct 29, 2011 | 07:25 AM
HondaPartsHero's Avatar
Technical Hero
There is an OBD1 PR3, for the JDM Integra XSi with the B16A. Do you have any check engine lights?
Old Oct 29, 2011 | 09:00 AM
momodc221's Avatar
your right about the ecu. and i do have a check engine light. but what would you go with in this situation subharness wise.
Old Oct 29, 2011 | 10:01 AM
Quik Chris's Avatar
1.) Check the engine light codes
2.) Take a picture and post it
3.) There is no "sub harness"
4.) I would get an OBD-I P72 ECU, OBD-I wiring harness (should have two plugs connecting to the distributor; OBD-II has one larger plug)
5.) Make sure there's enough oil in the pan, and subsequently enough oil pressure for the VTEC solenoid to operate properly
6.) Make sure the VTEC pressure switch wire is connected, and the VTEC solenoid plugged in to the OBD-I Engine harness.
Old Oct 29, 2011 | 06:19 PM
momodc221's Avatar
thanks for the info really helps a lot.
JesseBizz
13
May 24, 2009 07:26 PM
GSR-TRBO-DA
Jul 28, 2007 06:25 PM
3ghandles
Feb 26, 2007 01:27 PM
