98 dx hatch problem
Old Oct 26, 2011 | 04:50 PM
Revrs's Avatar
Icon2 98 dx hatch problem
okay this happen's more than often, but it dont sound right!
sometimes when im stopping and i put the clutch in and step on the brakes i hear a click noise like in the back!!
any idea's what it could be ?
if so what could i do to fix this or check!
Old Oct 26, 2011 | 06:20 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 98 dx hatch problem
In the back of what?
Old Oct 26, 2011 | 06:58 PM
Revrs's Avatar
like in the rear of the car, cant exactly tell from where but it more than likely sounds like in the rear axel's around there.
Old Oct 26, 2011 | 07:09 PM
raverx3m's Avatar
lol easy fix. remove all the loose tools and garbage from teh car if you have any
from the spare tire compartment too.
and see if it goes away.
brake pads are good?
i noticed alot of hondas with rear disk brakes the caliper rod dries out and seizes up misaligning the pad so it wears off uneven( 3 hondas i had all 3 did that all on pass side)
Old Oct 26, 2011 | 07:12 PM
Revrs's Avatar
hey thanks man im gonna try that out. i dont have no junk in the trunk. i might need to check the brake pads!
thanks.
Old Oct 26, 2011 | 07:18 PM
Hidenplanvew's Avatar
There are no rear axles... Is it a loud click or what? Metel on metel? is it only a set speed? hows the brake pedal feel?
Do you mean caliper slide pin? Your suppose to grease them like once or twice a year... but more then not it isnt that.
Could be bushings or a mount... get under the car and start shaking things around
Old Oct 26, 2011 | 08:17 PM
apexi_rsx's Avatar
def not a rear sway bar unless one was installed and the end links are bad. i would lift the car and try shaking the wheel or try to do it slowly in the driveway with someone else to listen to where it may be coming from.
Old Oct 26, 2011 | 08:55 PM
Revrs's Avatar
yes its a loud click, sounds like if its metal on metal.
the brake petal feel's normal.
Old Oct 26, 2011 | 09:01 PM
Dioxine's Avatar
Worn pads more or less would make a grinding noise. But if it only happens when you hit the brakes then thats probably where i would start.
zomart
Jul 2, 2004 08:18 PM
redwinqs
Nov 9, 2003 05:08 PM
CapnChunk
Apr 15, 2003 08:29 PM
BrandonClaps
Mar 9, 2003 10:25 PM
RTW DC2R
Mar 3, 2003 10:55 AM
