Upper control arm?
so im lowerd 2.5 in and my upper control arm/upper ball joint n the front hit the inside of the fender....what methods do you guys use to fix...jus a couple suggestions....i wanna go a little lower
...true..i take it you dont really raise the hood at any car events!! May have solved your problem, but you CUT the shock towers instead of alternate solutions, but i guess you can call that an ALTERNATE solution. I DNT LIKE...just my opinion.
THANK YOU !! I dont think ive seen anyone do that before on their car just to reduce knocking from that area. That should tell you that theres got to be another way or better products out there that can prevent this...i.e..THE CUTTING OF THE TOWERS..IMMENSLY!!
actually it was pretty popular to do that with uper control arm camber kits .. also if you cant tell it was cut from the factory and is only sealed with like a liquid glue or something.
true..i have noticed on mine as well..but im sure the reason of why they decided to EPOXY-it ( if you will ) back together was for a good reason..from factory im assuming.
jadugartir
Jan 6, 2008 12:16 PM
extracrunchie
Dec 20, 2004 09:47 AM
