EGR valve block off
so im just wondering i have a 1992 honda civic cx hatchback with a 1.5L and i was just wondering if anyone knows or could explain what all getting a egr valve block off plate would do? thanks
kind of but not really it sounds like its got a small miss when its sitting idling and when the engines cold and its idling it revs up and then drops down and back up and it does that until the engines in the normal operating temperature which ive figured it was just a vacuum leak but im really just basically trying to figure out anything i can do with out spending much money to get a little bit more power out of my engine ........
i was wondering the same thing i was having an idle problem and a few people said it was my egr but i dont know what to look for to even check it i have a 95 civic lx with a d15b2 block and a z6 top end
well my speed sensor is going bad so every now and then it throws the engine light for that but thats been the only one thats come on for over a year now
yea im gonna try this weekend and replace the vacuum lines all the hoses are original from 92 so im sure it wouldnt hurt to replace them i figured its got to be a vacuum leak basically just because i just put new plugs wires cap n rotor on it with in the last month and it did it even when i put the new ones on but would it also do it if the timing was off by a tooth? i had to change the water pump on it about 2 months ago i was really careful not to turn the crank or cam but just wondering as an option of the fix
Brembomaster
May 26, 2019 07:51 PM
