M&w pro 10/ecu issues?
Old Oct 25, 2011 | 12:49 PM
cornfed's Avatar
Default M&w pro 10/ecu issues?
Anyone out there had internal ecu issues or throw DTC due to radio freq. noise from the m&w pro 10? Keep throwing code 9 cyp sensor and ends up being bad ecu. This will be my 3rd ecu with code 9 now have sent to be fixed this time around. New distributor, wiring, etc. If anyone has got any input I would appriciate.
Old Oct 26, 2011 | 11:13 AM
twkdCD595's Avatar
Default Re: M&w pro 10/ecu issues?
I have not had any issues with mine but that obviously does not mean others have not.
How is your pro10 wired, you get a harness from t1 or something you made up?
Old Oct 26, 2011 | 05:10 PM
cornfed's Avatar
Yeah bought harness and everything from T1. First mounted coil and ignition box behind pass. front headlight like they say to do. Recently moved ignition box behind dash at heater core location and coil is mounted under battery tray. So location does not seem to be my issue.
EG RussE
Nov 27, 2016 09:18 PM
cornfed
May 23, 2016 06:29 PM
VTECth1s
Aug 3, 2006 01:01 PM
knocnemdown
Mar 12, 2004 07:30 PM
onyx00
Jun 29, 2001 12:20 PM
