Suspension & Brakes Theory, alignment, spring rates....
92' eg Brake Bleeding
Old Oct 25, 2011 | 11:21 AM
shotime's Avatar
Icon2 92' eg Brake Bleeding
I got a 92 eg and just put on overhauled the braking system;
new steel braided brake lines
new all 4 OEM calipers and pads
new slotted and drilled rotors
and did a drum to disc convertion off a 94 civic ex
Now I bled the brakes and the brake pedal felt firm but when i turn the car on the brakes went alot softer. my question is Do I have to bleed the brakes when the car is on???
Old Oct 25, 2011 | 05:44 PM
TPB's Avatar
TPB
Default Re: 92' eg Brake Bleeding
You may need to bench bleed your master cylinder if you let the fluid level get too low.
Old Oct 26, 2011 | 09:05 AM
Dogginator's Avatar
Daisy... Daisy...
No, you do not have to have the vehicle running. Is you pedal coming close to bottoming when running?
Old Oct 26, 2011 | 01:20 PM
shotime's Avatar
Icon2 Re: 92' eg Brake Bleeding
Ya when the car is running the pedal does indeed come close to bottoming. It makes me think i didnt bleed them enough?? but when i did bleed the brakes i did it till i didnt see any more bubbles.
When i did the rear disk conv. one thing i didnt do was upgrade the Master cylinder or the Proportioning valve. Some ppl said i didnt need to upgrade some ppl said i had to upgrade and some people said just upgrade the pp valve. So i got confused of what i had to or didnt have to upgrade and stuck with my eg pp valve and MC. (upgrade meaning getting those parts from a 4 disk brake car like the 94 civic ex where my rear conv. came from).
What made me think more that i didnt have to change those parts was when i had my gf working the brake pedal in between me bleeding the brakes. I saw all 4 calipers moving but the back ones didnt move as much as the front i thought prob. due to size of the caliper. My bleeding pattern was RR,RL,RF,LF hopfully I got that pattern right.
Im lost on why the pedal gets close to bottoming when the car is on and now when the car is off the pedal feels less firm. Im now looking into how to bench bleed the MC on Youtube as the one guy said i may have to do. Im also starting to think i have to at least get a upgraded non-ABS pp valve or MC or both?? this is my first time doing any kind of brake job/rear conv. so im open to any suggestions/help
Old Oct 27, 2011 | 02:46 AM
Dogginator's Avatar
Daisy... Daisy...
When you open the lines that far from the calipers, you allow a lot of air into them. I would bleed again with a friend and cycle between pumping and bleeding as quickly as possible to push the air along and prevent it from rising again. Bench bleeding the MC is not a bad idea either.
Old Oct 27, 2011 | 11:49 AM
shotime's Avatar
So I take it that im good with keeping my Eg pp-valve and MC after doing the drum to disk conversion and that I done the bleeding pattern in the right order?? But ill def will re-bleed all 4 calipers again once it stops raining in philly and def thanks for the extra help cause i need it
Old Nov 1, 2011 | 01:33 PM
Gekko's Avatar
Definitely make sure they are properly bled like other posters suggested. If that doesn't do it I'd look into the MC. There is a chance that when bleeding the brakes you messed up the seals in the MC. This explains it way better than I can: http://www.tegger.com/hondafaq/maste...ace/index.html
WhiteOnRice
May 24, 2010 12:36 AM
Scrapin4DR
Sep 9, 2009 09:27 PM
Mentasti
Sep 30, 2006 03:37 PM
gaydm
11
Apr 15, 2006 01:37 AM
DriveSideWays
Aug 7, 2004 05:34 AM
