compression ratio after the engine has been built
Old Oct 23, 2011 | 01:33 AM
alperx's Avatar
Default compression ratio after the engine has been built
hi
a friend of mine has bought eagle rods and cp pistons for his Integra LS. b18a1.
the engine has been built by a mechanic who doesnt know much about honda.
now he learned that eagle rods could have been b16 rods.
and he is not sure if the rods are for b16 or b18.
I told him that b16 rods are 3mm shorter than LS rods, however, now the engine has been built already.
Is there a way to check the compression ratio from outside ?
or can it be done via removing one of the rods and check without removing the head ?
Thanks
Old Oct 23, 2011 | 02:18 AM
rickyracer's Avatar
Default Re: compression ratio after the engine has been built
i'm not sure but i think if you spin the block and get the piston to the top, it should be flushed with the sleeve. if it sits lower then the sleeve then that should answer your question.
Old Oct 23, 2011 | 10:42 AM
alperx's Avatar
this is the picture : pistons are wiseco 9:1 for this block and head. -12cc
so what are your comments ?
Old Oct 23, 2011 | 11:54 AM
Turbo-LS's Avatar
looks like the pistons are just under the deck surface which is where they are supposed to be for proper piston to head clearence, i would have to say you have the correct rods in there. if they were B16 rods you would have a bit of distance from top of piston to top of block deck
Old Oct 23, 2011 | 12:48 PM
alperx's Avatar
thank you very much.. I like this site for the great experience some users have..
Old Oct 29, 2011 | 12:23 AM
rickyracer's Avatar
yeah i agree..seems to be pretty close to the top of the deck....that motor should run fine.
GT500FTW
Jul 29, 2012 05:35 PM
x91crxsix
Jun 29, 2006 08:09 PM
tgreaves
Dec 22, 2005 05:53 AM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
