Welding something with ceramic coating
Old Oct 22, 2011 | 02:12 PM
Lewy. Dee Ayy's Avatar
Default Welding something with ceramic coating
My manifold cracked and its coated
It needs to be re-welded whats the best way to go about this? Get it sand blasted off? I want to make sure there is no contamination so it does not crack again. I hate taking my cars apart for something so stupid.
Old Oct 22, 2011 | 03:40 PM
titwack's Avatar
Default Re: Welding something with ceramic coating
A flap wheel might work if it's easy to get to
Old Oct 22, 2011 | 03:44 PM
Muckman's Avatar
Moderator in Chief
Im in the same situation. Ceramic coated manifold cracked and need to know how to prep it for welding.
Old Oct 23, 2011 | 06:17 AM
Anyone else have any suggestions? Would they company who coated it have a form of stripper they uses specifically for the coating they use? I really want to make sure they welds are not contaminated so it does not crack again
Old Oct 23, 2011 | 09:32 AM
titwack's Avatar
What I read around from online is sanding it off, that seems like what most people are doing
Old Oct 28, 2011 | 05:19 PM
awill4x4's Avatar
The trouble with sanding coatings is it tends to smear the coating into the material. I've had success in the past with sanding the majority of it off and then using a fine carbide bit in a die grinder to clean the area to be welded.
Regards Andrew.
Old Oct 28, 2011 | 08:20 PM
ToxicFabrication's Avatar
OG Fabricator
Media blast it off, only way to really remove it with out grinding it into the base material. Common sense really..
Old Nov 4, 2011 | 06:59 AM
SpeedwayCoating's Avatar
x2
Hatch99
Welding / Fabrication
Jan 25, 2013 10:22 AM
siblues
Jun 22, 2010 09:11 AM
punkinbeck
Dec 22, 2008 01:03 PM
Turbo-charged
Nov 27, 2004 03:38 PM
