Cigarette Lighter Not working?
Old Oct 22, 2011 | 09:36 AM
UniqueX707's Avatar
Default Cigarette Lighter Not working?
My cigarette lighter does work when i plug like chargers or anything doesnt even work to heat! I check the fuse and nothing there not blown. So do any of you guy know what can be wrong?
Old Oct 22, 2011 | 10:55 AM
virgineg6's Avatar
Default Re: Cigarette Lighter Not working?
Check for power and ground at the outlet.
Old Oct 22, 2011 | 11:07 AM
hyperblu's Avatar
The contacts inside the outlet may need to be taken apart and cleaned. If im not mistaken, it is probably linked with another circuit like the hazards or something. Check ALL your fuses. not just the cig lighter.
Old Oct 24, 2011 | 09:15 AM
UniqueX707's Avatar
I have check all the fuse it still nothing! I'll check the circuit
Old Oct 24, 2011 | 09:24 AM
grumblemarc's Avatar
The Grumpiest
When did it STOP working?
Old Oct 24, 2011 | 09:27 AM
UniqueX707's Avatar
When i bought the car it wasnt working either
Old Oct 24, 2011 | 09:30 AM
The Grumpiest
Have you actually pulled the panel off and inspected the wires physically or are you just looking at the plug?
Old Oct 24, 2011 | 10:19 AM
apexi_rsx's Avatar
pull the panel and look at it it has a one wire positive and a wire to ground it. many get real loose and it falls off.
Old Oct 24, 2011 | 10:21 AM
UniqueX707's Avatar
I fixed it now i pulled the panel off and i say the clip wasnt connect and i connect and it works perfect..
migsr01
May 7, 2014 12:15 AM
97njsilverhatch
Jan 29, 2011 06:08 PM
kturner2007
12
Jan 9, 2007 10:03 AM
icedlee
May 1, 2005 03:27 PM
SpoonIntegra808
Nov 13, 2004 05:51 PM
