Wheel size and offset
I am ordering wheels and tires (17's w/Toyo FZ4 205/40/17) later today and I just want to make sure of a couple things...
Lug Pattern: 4 X 100
Offset: 40 - 45
Is this the lug pattern for a 01 gsr off and what is the most common offset people use. The car is currently lowered with the eibach pro kit but might put hr sports on for a lower height, so what would the best offset be?
Is there much variance in weight between companys. The wheels I am looking for a most likely going to be a seven star by either konig, katana, enkei, exel, giovanna. What are good brands?
[Modified by grngsr01, 12:02 PM 10/6/2002]
Offset: 40 - 45
I think with a 17" wheel you will want a +45 offset. I think +40 would be cutting it too close. Especially if you loweer more. Wait till someone else chimes in though, I'm no expert....
Bolt pattern is right, so is the offset. 42 is supposed to be best but 40 is common.
Depends on the wheel I suppose. If you're worried about weight why are you going with a 17
haha j/k
haha j/k
haha j/k
haha j/kThread
dt98gsr
Honda Civic (2006 - 2015)
35
Mar 10, 2008 12:59 PM
