HELP! electtical issuse
My driver side headlight/signal doesn't have any power at all, I checked fuses there still good,tested volts no power, but the driver sidde has power and works just fine.... This is really turning into a real head scratcher.. any info would be great Thx
OK, to start we will need MM&Y of car, I am assuming it is a G3 Integra and will go with that unless you say diff.
Also, exactly what lights do not work...
"My driver side headlight/signal doesn't have any power at all"
"but the driver sidde has power and works just fine.... "
Your going to have to clarify.
Also, is it high beam, low beam, front signal, front side marker and/or park lights??? 94
Really? Good to know. I just thought it was one fuse for front headlights. I never checked but good to know!
Actually there are 4 fuses for the head lights...
fuse 10-10A left high beam and high beam indicator.
fuse 9-10A right high beam.
fuse 21-10A right low beam.
fuse 22-10A left low beam.
Above are in under dash fuse box.
The signal lights are on one fuse, fuse 26-10A in AUX fuse holder.
The drivers side signal has nothing to do with the fuse, it is either a bad bulb or a connection problem, if you tested for power and there was none then there is a connection problem.
To be clear are you are talking about the duel filament bulb, [park and signal light] in the bumper, or do you mean the single filament front side marker, [also a park and signal light that is controled by the ICU]??? 94
Realdon65
Honda CR-V & Element
Sep 4, 2021 12:15 PM
