Second O2 sensor wire harness location.
Old Oct 20, 2011 | 09:10 PM
wasanissanFL's Avatar
Default Second O2 sensor wire harness location.
I'm putting together a custom Random Technology cat for my 98 gsr sedan so i need to remove the rear o2. What's the best way to get to the 2nd O2 sensor wire harness?
Old Oct 20, 2011 | 09:33 PM
mark@silbernage's Avatar
Default Re: Second O2 sensor wire harness location.
It goes through the floor underneath and slightly forward of the stereo console, the wire has a rubber boot that keeps water from coming up the hole, and the cat is right underneath. You can probably see it if you get down on either driver or passenger side with a flashlight and look at the floor under the dash - center.
Mark
Old Oct 20, 2011 | 10:06 PM
Thanks for the reply Mark. I've seen the rubber boot under the car. I'm just needing to know the easiest way to access the wire harness inside the car. So you say it's near the stereo area? Do i need to remove any interior parts to see it?
Old Oct 20, 2011 | 11:16 PM
I don't think so, but it may be hidden under a flap of carpet.. I'd have to go peek again.
Once the wire is inside it has a 4 pin grey connector just line the #1 O2 sensor. I'm thinking it's hidden under/behind the carpet right where the floor turns up to the firewall?
Mark
Old Oct 22, 2011 | 05:45 PM
BUMP anyone else
Old Oct 23, 2011 | 09:50 AM
safedriver's Avatar
I pulled back my passenger side carpet and made a slit. I was able to slide my hand in and free up some slack in the cable (under the radio area that connects to the 2nd o2 sensor plug).
Since then, I can go under the car and pull the o2 sensor's (water proof) boot, towards the cat, and the plug comes out through the floor. Then I can unplug it.
If you haven't had the o2 sensor off of the cat, in a while, I recommend that you remove the cat, inorder to remove the o2 sensor.
Old Oct 23, 2011 | 01:16 PM
lhd dc2's Avatar
The easiest way through experience is under the car.
Old Oct 24, 2011 | 09:11 AM
BigDaddyRich's Avatar
I changed mine by lifting the carpet up just slightly to the right of the gas pedal behind the center console. Very easy access. You will see the harness plug and everything right there.
Da_1991
Nov 10, 2013 07:14 PM
EX-T
12
May 24, 2008 08:01 PM
lv6l
11
Apr 8, 2008 01:10 PM
_gurusan_
Aug 2, 2006 05:59 PM
Del_Slowest
Oct 29, 2003 02:38 PM
