Honda S2000 Honda S2000
HELP! Engine light on after ECU been plugged back
Old Oct 20, 2011 | 05:49 PM
dojo19xx's Avatar
Default HELP! Engine light on after ECU been plugged back
Hi
Please help
i unplugged the ECU and plugged it back again last night because the box was not properly mounted. However the check engine light came on today and after 30mils of drive it is still on....
does anyone know thats gonna be a problem?
if not is it posible to reset it my self?
thank you in advance!!
Old Oct 21, 2011 | 03:14 AM
dojo19xx's Avatar
Default Re: HELP! Engine light on after ECU been plugged back
oh and now key will not turn to lock position and stucked in the ignition....
i tried to reconnect the battery, then i did get rid of the check engine light but still cant turn the key to lock.... i dont want my car get stolen...
Old Oct 21, 2011 | 03:54 AM
JUSTINTHECOASTI's Avatar
First off understand a cel indicates theres something wrong, id pull/read the code first before attempting to erase it
Old Oct 21, 2011 | 05:41 AM
lke2drvgsr's Avatar
Have you tried pushing in the key before/while turning it? Check the CEL code and then report back.
Old Oct 21, 2011 | 05:45 AM
Vyndictive's Avatar
You think the check engine light has made it so you can't remove your key from the car? lolz.
Why did you have your ECU unplugged again? Were you installing something, or just unplugged it for *****?
Old Oct 21, 2011 | 10:12 AM
dojo19xx's Avatar
i didnot install anything.
the ECU box was't mounted to the wall, so i unplugged it to mount and plugged it back.
Old Oct 21, 2011 | 10:46 AM
TheMuffinMan's Avatar
He knows where you live!
So....your car is OBDII....plug in a scanner and get the code.
88crx Osaka
Aug 20, 2011 10:42 PM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
Project_EK
Aug 13, 2005 04:08 PM
nek0
Jul 9, 2003 04:49 PM
TJP_AccordV6
Jan 31, 2003 04:06 AM
