b16 S1 cable trans in ef ! need help
Old Oct 19, 2011 | 09:33 PM
88HATCH(:'s Avatar
Default b16 S1 cable trans in ef ! need help
all gears work fine accpet 5th !
pop into gear , let the clutch out and nothing , no pops , grinds, shake , or shatter ! no nothing !! feels like im in neutral ..
what might this be ?
in proper length on shift linkage ? 5th gear needs to be replaced ? help ?
Old Oct 19, 2011 | 11:48 PM
ef yu's Avatar
Default Re: b16 S1 cable trans in ef ! need help
im gonna go with a bad trans. if all else gears works fine then i dont see why the linkage should have a problem changing into 5th. Is it a home-made linkage?
Old Oct 20, 2011 | 10:30 AM
deuce_Fc's Avatar
like stated above proper linkages??? again it could be a bad tranny components, double check the tranny, my suggest is pull the tranny out and open the case, and manually put it gear to see if it will get in gear. what i normally did was used a screw driver and insert in where the linkages went and started shifting gears to see what was the issue.
Old Oct 20, 2011 | 10:40 AM
88HATCH(:'s Avatar
theyre homemade linkages .. not my doing , got it that way .
i might end up getting a cable ls trans and juss swapping it .
rstchris
Transmission & Drivetrain
Jan 29, 2012 04:09 PM
My_EFsedan
Mar 26, 2010 10:04 PM
andertom
15
Mar 24, 2009 08:57 AM
rexfan
Nov 4, 2008 04:39 PM
bob06
Jul 6, 2005 10:34 PM
