Code 09 (OBDI) ls - CYP Sensor, can I rebuild the dizzy?
Old Oct 18, 2011 | 04:11 PM
sebTeggy's Avatar
Default Code 09 (OBDI) ls - CYP Sensor, can I rebuild the dizzy?
I have a CYP sensor (Cylinder position sensor) which is code 09. Ive had this code for almost 2 years and I think its time to FIX IT!
I don't really think this code affects me since it pops up from time to time after 30 mins of driving and only if I am stopped at idle for more than 10 seconds. I have aircare coming up (emissions) and they don't allow any CELS.
Can I rebuild the CYP sensor inside the dizzy? Any parts? Do I need a donor dizzy? Or should I just get a new dizzy all-together.
And if anyone has any tips on code 09, I would appreciate that too!
Old Oct 18, 2011 | 06:09 PM
mouab18c1's Avatar
Default Re: Code 09 (OBDI) ls - CYP Sensor, can I rebuild the dizzy?
Just buy a new dizzy. The sensor itself is fairly expensive.
Old Oct 18, 2011 | 08:01 PM
sebTeggy's Avatar
I usually avoid replacing over fixing/cleaning. I am sort of strapped for cash, but if the ONLY solution is to buy a new dizzy, I will.
Can I take a donor distributor (maybe 20$?) and disect it?
Old Oct 18, 2011 | 08:22 PM
mouab18c1's Avatar
If you get a donor distributor with the CYP sensor still functioning then yes you can swap it out. Have you tried looking in the H-T marketplace? I bought a used obd2 ls dizzy for $60 a few weeks ago. Try looking there.
Old Oct 21, 2011 | 06:20 PM
sebTeggy's Avatar
Okay, ill look around!
Any other tips to rebuilding the dizzy?
Old Oct 21, 2011 | 09:28 PM
mouab18c1's Avatar
Nope never done it. I always figure buying a used dizzy would be less of a headache.
Car Tweaker
Apr 5, 2009 01:13 PM
civicflow
Mar 3, 2006 11:30 AM
Forrest Gump 9
May 14, 2004 04:59 AM
RaIn
Apr 20, 2003 08:05 PM
