Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
vsa light on and horn doesn't work
Old Oct 18, 2011 | 03:49 PM
wakenbake215's Avatar
Icon6 vsa light on and horn doesn't work
the first time i seen this happen i replaced the horn fuse and it never came back on for months. i just got my car back from the body shop and it came back on. i replaced the fuse but it keeps blowing the fuse. i been trying to research the problem and i been reading that the "yaw rate sensor" causes the VSA light to come on. has anyone been having the same problem and if so can you give me some help.
Old Oct 19, 2011 | 05:53 AM
Default Re: vsa light on and horn doesn't work
nothing? no one?
Old Oct 19, 2011 | 07:03 AM
bee guz's Avatar
If your car had a hit, check the wires in that area, if panels were replaced check for wires that were crushed or caught between panels.
That happens if the body shop is in a rush and they don't check the car out.
In fact I would take the car back, they created the problem make them repair it.
Old Oct 19, 2011 | 09:00 AM
well i found out the reason why the fuse kept blowing. my brake lights are now working when the brake pedal is stepped on. now when i turn on my lights my tail lights isnt turning on
Old Oct 19, 2011 | 12:36 PM
bee guz's Avatar
Now you need to check the tail light fuse.
Old Oct 19, 2011 | 02:01 PM
problem solved.
Old Feb 4, 2012 | 07:13 AM
richiejr416's Avatar
I'm having the same issue, how'd you fix it?
Old Feb 7, 2012 | 07:25 PM
tpatt's Avatar
I believe it was the fuse. Horn and tail light are on the same fuse. Check under the hood in the fuse box to see what # it is. If this is your problem, your tail lights are not working, so have someone tell you if they're out. If they're working, but your horn is not, it's probably the horn itself that went bad. Mine went out around 50k, so let me know if you need any advice on changing that. It was a minor project for a mechanically challenged guy.
Old Feb 8, 2012 | 07:06 AM
Thanks, I got it worked out.
Old Feb 8, 2012 | 07:45 AM
tpatt's Avatar
So was it the fuse?
Terry36
Acura TL, RL & ZDX
Nov 19, 2007 11:19 AM
booja
Sep 7, 2004 10:20 AM
Sassafrass
11
Sep 4, 2003 01:18 PM
becones
Apr 18, 2003 11:38 AM
