turbo supra map senser need help
On the 1jz map sensor:
1 (brown wire) - ground
2 (light green/black stripe) - signal
3 (blue/black stripe) - 5v
Same wiring as a GM sensor.
No idea how you are going to calibrate the Supra sensor.
Or are you going to doing something trick like running the Supra MAP into an 'AFC neo' and then to the ECU?
He will do it by overnighting parts from Japan, silly. I thought everyone knew this?!?!
OP - just do yourself a favor and run a MAP sensor that the tuning software support. Unless you have the exact specification for calibration - its just a whole lot more trouble than it's worth = blown engine.
