? about misshifting
Old Oct 5, 2002 | 10:12 PM
AccrdATK's Avatar
New User
Default ? about misshifting
if you misshift into third from fourth while in vtec, would the rpm jump past the fuel cutoff? i was up late last nite driving home... i did this ( i kno pretty stupid) but ya.. rite when i engaged it jumped to fuel cutoff and was wondering what do you think the outcomes are of my motor... throttle response feels as if it was affected, but could be my mind playin tricks... theres no pinging.. idle is still the same... motor still sounds the same... any suggestions? recommendations?
Old Oct 5, 2002 | 10:23 PM
davidnyc's Avatar
Default Re: ? about misshifting (JdMR-536)
downshifting doesn't go into fuel cutoff. miss a downshift and engine can get damaged. (if not caught in time). fuel cutoff is only good on acceleration.
get a leak down test. If things are good, then no problems.
Old Oct 5, 2002 | 10:51 PM
hooptie157's Avatar
Default Re: ? about misshifting (davidnyc)
damnnit you said that before me
Old Oct 5, 2002 | 10:52 PM
hooptie157's Avatar
what he said X2
[Modified by hooptie157, 2:57 AM 10/6/2002]
Old Oct 6, 2002 | 12:50 AM
4-1-1's Avatar
Default Re: ? about misshifting (hooptie157)
Hope you saved it
Old Oct 6, 2002 | 12:57 AM
vtec.dc2's Avatar
lets put some light on this... at what speed did you downshift?
Old Oct 6, 2002 | 03:28 AM
AccrdATK's Avatar
New User
Default Re: ? about misshifting (vtec.dc2)
funny thing.. i dont remember... i guess theres a lesson to be learned.. dont drive late at nite real tired (around 4) was out with a bunch of friends all nite... dont quite remember what speed... i was in fourth.. when i downshifted into third.. and i just saw my tach jump to fuel cutoff and so i pushed in the clutch.. and slowly drove to a gas station to check to see if anything was wrong.. noticed a slight decrease in throttle response... no idle problems... and it started right up this morning... no knocks or pings from what i can hear!
Old Oct 6, 2002 | 08:42 AM
Dave-ROR's Avatar
it it only hit 9k or so I wouldn't worry about it. You can just to a compression test IMO, but I've never heard a motor wth bent valves idle the same
Old Oct 6, 2002 | 10:50 AM
davidnyc's Avatar
Default Re: ? about misshifting (Dave-ROR)
I am no tech guy... but with bent valves does he need to do a compression test or a leak down test to test for damage? (I am honestly not sure of the difference between the tests. I think one checks valves other cylinders???? If someone can explain.)
Old Oct 6, 2002 | 12:06 PM
01-1293's Avatar
Default Re: ? about misshifting (Mojito)
make sure there are no ticks whatsoever........its really obvious when you really fugg up a few valves.........but sometimes its hard to detect minor valve damage by sound
Old Oct 6, 2002 | 01:07 PM
Dave-ROR's Avatar
a compression test will show that something is wrong. that's all I meant. Leakdown tests are good, but a comp test will show a bent valve.
Old Oct 6, 2002 | 01:16 PM
Tommy_Gunns's Avatar
Holy crap dude. You redlined 4th and miss-shifted into 3rd. That's a first...usually it is redline 3rd and miss-shift into 2nd. Either way, it is not good for the motor.
[Modified by Tommy_Gunns, 4:17 PM 10/6/2002]
Old Oct 7, 2002 | 12:12 AM
AccrdATK's Avatar
New User
Default Re: ? about misshifting (Tommy_Gunns)
hmm.. thanks for all the helpful replies, my friend whos training to become a toyota tech is going to do some testing to my car on tuesday, to see if i messed anything up, wish me luck. Thanks!
Old Oct 7, 2002 | 12:16 AM
Reid's Avatar
Global Moderator
You were redlining fourth gear under those conditions?
Old Oct 7, 2002 | 12:27 AM
boostinb18's Avatar
Default Re: ? about misshifting (Reid)
yah if you did let it go too high you will float a valve or several valves and bend them....my friend has a gsr in his hatch and went from top of third into second and hit about 12000 rpm?!?!? well anyways 8 bent valves and no compression in the 3rd cylinder he still pulled a 14.9 at the track! now he has a fully built JG head and some other goodies......but anyways the throttle respnse is probably just in your head......and get a comp test becasue pretty much the only thing that could have happened would be floating a valve.....and that will usually make your car run lreally bad especially at idle!
good luck!
Old Oct 8, 2002 | 10:52 PM
AccrdATK's Avatar
New User
Default Re: ? about misshifting (boostinb18)
hmm... well.. i took it to the dealer.. there going to do some tests on thursday.. i got it done under warranty(luckly)... hopes every thing is okay
Old Oct 9, 2002 | 04:46 AM
1GreyTeg's Avatar
Don't be too quick to say "I got it done under warrenty." Especially if you don't know the results yet. If they suspect driver error which BTW this is, they may Not cover the costs of fixing whatever you broke and then it turns into a very expensive lesson. There have been more than a few HT members with varying results on this subject.
You'll know soon enough, Good luck,
A.
Old Oct 11, 2002 | 02:55 AM
AccrdATK's Avatar
New User
Default Re: ? about misshifting (1GreyTeg)
well... they decided it is getting done under warranty...i told the dealer what happened...so they ran the tests... they said its going to be a lil bit.. so i got a loaner car(integra)... i wonder how long its realliy going to take
Old Oct 16, 2002 | 06:47 PM
wesuri's Avatar
shame on u revin so high.... i think its time for that skip barber or jason stewart driving school
Old Oct 16, 2002 | 06:54 PM
Haunt's Avatar
missshift
Everyone's done it...just not as bad as others
Old Oct 16, 2002 | 08:02 PM
ITRbroham's Avatar
shit post warrior
Default Re: ? about misshifting (Haunt)
Hope this was a learning experience for you! Next time you might not get so lucky!
Old Oct 16, 2002 | 09:54 PM
98cwtypeR's Avatar
Default Re: ? about misshifting (ITRbroham)
how much does it cost usually to fix a bent valve?
br8crumb
May 22, 2014 04:53 PM
vtec92accord
Mar 7, 2007 05:04 AM
SOHCD16y8
Apr 13, 2006 03:15 PM
EK22snatch
Aug 23, 2004 06:31 PM
