Exhaust advice
Old Oct 16, 2011 | 04:54 PM
ohnoitsryan's Avatar
Default Exhaust advice
So I have a bad cat and can't find a used one and don't feel like spending six hundred on a new one. Can I use a gsr cat with no noticable power difference or smog problems?
Also, I bought the car with a greddy header but I think it gets so hot it's almost melted my fan wire. I have the original header, should I put that back on? I know it's preference but is the header giving me any noticable power boost?
Old Oct 16, 2011 | 10:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Exhaust advice
The header melted your fan wire? Why don't you just re-route the fan wire away from the header? I have no idea if the Greddy header added power. Probably not much.
The OBD2 GSR cat was a much longer design. So no. I don't beleive that the GSR cat will work. The non GSR cat might be the same part number as the ITR cat, though. Look for one from a LS/RS/GS/SE. When I replaced mine, I don't remember there being a difference between the regular model cat and the ITR cat. You can cross check part numbers at www.hondaautomotiveparts.com
Old Oct 17, 2011 | 09:14 AM
Tyrant_007's Avatar
You might call Hytech (http://www.hytechexhaust.com/). IIRC their cats were $175 last I checked. Way cheaper than $600...
slickciv
Jan 21, 2007 06:56 PM
jdmxxdc2
Jan 13, 2005 11:26 AM
1998teg
Aug 23, 2004 03:59 PM
GothicTuner
Mar 26, 2003 12:41 PM
GothicTuner
Mar 26, 2003 11:51 AM
