header, cat, exhaust, installation problems
Old Aug 23, 2004 | 09:44 AM
1998teg's Avatar
Default header, cat, exhaust, installation problems
does anyone know if a 2.25 cat will bolt up to a 2 inch header. The reason i ask is my header is 2 inches and exhaust is 2.36. Ive heard that the 2.36 will bolt up to the 2.25 no problem but but i dont know if it will bolt to the 2.25. i can get a custom 2 to 2.25 cat for 170. but if the 2 inch header will hook up to the 2.25 cat i can get a 2.25 in and out cat for 70. if you know please fill me in.
Old Aug 23, 2004 | 10:46 AM
94gsr_vtc's Avatar
Default Re: header, cat, exhaust, installation problems (1998teg)
yes everything will bolt up perfect if the collector on the header is 2". im running the comptech 4-2-1 2" with a 2.25" carsound cat and 2.36" greddy evo and have no problems except its loud as hell ha.
Old Aug 23, 2004 | 02:03 PM
sabotage7's Avatar
Default Re: header, cat, exhaust, installation problems (94gsr_vtc)
hey, Mike....you dont happen to have the part# for that carsound cat you have do you? bc i think i need that same one bc i also have a 94 gsr and i have a comptech header and greddy sp cat back.......everyone i know that has that sorta setup has obd II, so the part# is diff.
Old Aug 23, 2004 | 02:42 PM
1998teg's Avatar
Default Re: header, cat, exhaust, installation problems (sabotage7)
while were at it does anyone know the part # for the 1998 ls carsound cat.
Old Aug 23, 2004 | 03:23 PM
94gsr_vtc's Avatar
no i bought it used but it has 2 o2 holes, so one is just plugged up, it works fine tho. nevermind i still got the box- it is 94065
Old Aug 23, 2004 | 03:41 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr_vtc &raquo;</TD></TR><TR><TD CLASS="quote">yes everything will bolt up perfect if the collector on the header is 2". im running the comptech 4-2-1 2" with a 2.25" carsound cat and 2.36" greddy evo and have no problems except its loud as hell ha.</TD></TR></TABLE>
of course cuz you aint got resonator that why...if you are running comptech, im just curious why do you run 2" header and 2.25cat and 2.36evo....size is not constant i affraid you might not gain as much as u wish......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998teg &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if a 2.25 cat will bolt up to a 2 inch header. The reason i ask is my header is 2 inches and exhaust is 2.36. Ive heard that the 2.36 will bolt up to the 2.25 no problem but but i dont know if it will bolt to the 2.25. i can get a custom 2 to 2.25 cat for 170. but if the 2 inch header will hook up to the 2.25 cat i can get a 2.25 in and out cat for 70. if you know please fill me in.
u can make anything bolt on anything...talking about 2" and 2.25 aint' a problem but you shouldn't do it...cuz piping is not constant the same size...performance might get worse or gain less than it supposes to gain...
well i think you should buy a 2.25 header and cat 2.25 and piping 2.25 for maximun benficial....exhust inlet 2.36 is ok...cuz at this point pressure going out at bigger diameter with shorter distance 2.36" inlet to whatever ur muffler tip is...
im sure you know im not recommending 2" header with larger piping after...no point just waste money...u might as well save up little more and do everythign at once
Old Aug 23, 2004 | 03:57 PM
94gsr_vtc's Avatar
Default Re: header, cat, exhaust, installation problems (yeegsr)
hmm i would have to disagree with you on that one. im no expert but i dont know of any 2.25" header. also i know the size isnt supposed to be one size like that unless everything is 2.5". somebody please correct me though
Old Aug 23, 2004 | 03:59 PM
94gsr_vtc's Avatar
also i didnt get a 2.5" header so im not gonna change my setup. also why would anyone downgrader to a 2.25" exhaust? just to keep everything consistant? sorry i dont really get it
Broken Devil
Oct 3, 2005 09:55 PM
honda95civic
Welding / Fabrication
Feb 9, 2005 07:57 PM
1998teg
Jul 29, 2004 11:29 AM
R.S.
Sep 26, 2003 06:57 AM
GothicTuner
Mar 26, 2003 11:51 AM
