98 civic cluster in rex
Old Oct 5, 2002 | 08:46 PM
xXx Justin xXx's Avatar
Default 98 civic cluster in rex
i am putting in the 98 civic dx cluster in my 88 rex. i am tring to figure out what i need to make this work. i want the dx cuz it doesn't have a tach. do i need to try and get the plug and part of the wires that plug into the cluster?
and how do i hook up the speedo? i am running a d16z6 all converted to obd-1, but i am still using the 89 crx Si cable tranny? how hard is this going to be.
and also, do i need to geta guage cluster cover from a 90-91 crx? thanks everybody.
Old Oct 5, 2002 | 08:57 PM
thaiphob's Avatar
Nikon!!!
Default Re: 98 civic cluster in rex (bstdvtecRx)
you'll need to grab a vss from the 98 civic also....(not 100%)
Old Oct 5, 2002 | 09:14 PM
Default Re: 98 civic cluster in rex (thaiphob)
so i do need the plug and acouple inches of wire from the 98 cluster, and the vss. but how do i get that to work with my 89 crx Si tranny? just tring to figure out how it is all gana work before i go buying things and it not working. thanks again
Old Oct 6, 2002 | 08:00 PM
ok, if i get a cluster from a 98 civic dx, can i use the vss and plug and everything else from a 96 civic ex? i have access to all that... thanks for any help
Old Oct 6, 2002 | 08:25 PM
thaiphob's Avatar
Nikon!!!
you'll need the vss cable off the 98 civic tranny to replace yours on your rex
[Modified by thaiphob, 9:25 PM 10/6/2002]
Old Oct 6, 2002 | 08:35 PM
but will the electronic vss from the 98 obd-2 tranny and all that work in my 89 crx Si tranny, with an engine swap that is converted to obd-1 running p-28? getting twisted enough for ya? ha..thanks though man
Old Oct 6, 2002 | 09:56 PM
thaiphob's Avatar
Nikon!!!
brain freeze.............
Old Oct 7, 2002 | 04:35 PM
ok, list setup to clear it up a little to anybody brave enough to make a guess.
88 crx dx
95 d16z6
running obd-1 p28
using 89 crx Si 5spd tranny
wanting 96-99 civic dx (no tach) guage cluster
need to know what parts i need to use to make the speedo work with my tranny and ecu. thanks for helping..
[Modified by bstdvtecRx, 4:39 AM 10/9/2002]
Old Oct 8, 2002 | 07:38 PM
nobody out there brave anough to try and put out a complete parts list..like what year and model car for each part. Please?!?!
pliskin8
Feb 12, 2010 10:51 AM
jmoney1698
Feb 21, 2008 04:34 PM
ejkid
Oct 22, 2006 06:39 PM
Bitpicker1011
Jun 21, 2004 11:50 AM
Shocka1998LX
Jan 7, 2004 08:23 PM
