Clutch acting up unsure of what it is
Old Oct 15, 2011 | 11:36 PM
ricerollz's Avatar
Icon2 Clutch acting up unsure of what it is
Okay so i got my car back from the shop today and they said my clutch was just loose so they tightend it now i drive it for 2 hours then all of a sudden my car wont go into gear so i pull off too the side shut off my car and try too start it and then go still doesnt work but now my car wont start its like i have no clutch i cant even push start it when you pop off on the cluth nothing happens what can it be??
Old Oct 16, 2011 | 05:36 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Clutch acting up unsure of what it is
Very high possibility your clutch cable snapped... since you too it to a shop I am not sure it you'll understand this but...
Look between where the stock location of the battery and lower radiator hose is. You will see a big black plastic nut with "ribbed" edges. That is how you tighten and loosen the clutch cable. The cable continues down to an arm. Is the cable snug or does it have a lot of slack in it - it is it even still attached to the arm?
Old Oct 16, 2011 | 07:20 AM
ricerollz's Avatar
Okay my friend also said its possible they didnt allign my clutch right and it couldve slipped if this happpend how would my car act??? I'll also check the cable today thanks N3va3vaSatisfi3d
Old Oct 16, 2011 | 07:23 AM
ricerollz's Avatar
the clutch pedal also feels like it goes does way to easy so can that also help??
Old Oct 16, 2011 | 07:37 AM
all-motor-crx's Avatar
if the clutch goes down to easy it seems to me like the clutch cable, that's the only thing between your clutch and the pedal so check what N3va3vaSatisfi3d said
Old Oct 16, 2011 | 11:22 AM
///Mathew's Avatar
Well the only way to align a clutch is by having the transmission out, and I'm guessing they didn't when they had your car in the shop.
When you say they "tightened" the clutch, you mean the cable right?
If so, I concur with what the other posters said.
Old Oct 16, 2011 | 01:06 PM
ricerollz's Avatar
yes and the cable isnt snapped BUT hopefully this will help?? like i said the clutch pedal was sitting side ways?? i went under there and checked it out and it seems like this piece is broken
theres how the clutch pedal sits
thats whats broken can that affect it??
i cant shift or even start my car
Old Oct 16, 2011 | 01:21 PM
DO IT ON ALL FOURS
Uhhh... Yes. Obviously you can't disengage the clutch or switch if the pedal is broke. That is your problem.
Chi925
Transmission & Drivetrain
Jan 31, 2012 05:55 PM
hatcht9x
17
Jul 19, 2008 06:04 AM
95legacy
Sep 24, 2007 09:55 AM
G2_Fella
11
Jul 6, 2005 03:08 PM
lina sok
Sep 24, 2004 03:22 PM
