EM1 Distributor oil leak
Car is a 2000 civic si with the original b16.
My distributor is leaking oil at what appears to be the o-ring. I have replaced the o-ring with the OEM one, and it still leaks. There is a little bit of shaft play, so could there be an internal problem? I don't want to replace the dizzy if that's not the real problem.
-Dan
-Dan
I have the same problem, after I replaced the O-ring I cleaned where it leaked with engine degreaser and after a month altho is not dirty with oil as before there's seems to be a smaller leak as the tranny is dirty with oil again.
ya my tranny gets covered in oil pretty quick, and then it drips onto my driveway. I can clean it all off and start my engine, and watch it drip from the o-ring area.
But I guess my question is: is there supposed to be any shaft play at all, or does any shaft play at all mean the dizzy is bad?
I thought I had the same prob with my d16y8, the honda mechanic said that even after you replace the o ring if there is shaft play it will still leak, this common, only real solution is a new dizzy.
He was wrong with my car and it was not my dizzy leaking again (had o ring done before)
By the way are you sure it is the dizzy, did you take a flash light and look directly under it and put your hand to make sure it is fresh oil? Have you replaced your vtec spool valve gasket yet?
I should of been clear, I went in for the spool valve gasket to be replaced again, I noticed oil pooling, I made sure was with the mechanic, has said he thinks it is the dizzy, I had him do the spool valve again with honda bond. A week later it was still leaking oil, then I just replaced the top spool valve gasket on my own ( he did the body one that meets the block) seems better 2 weeks later still oil on the full mark.
I was chasing this leak for years.
Side note, I was back last year to the dealer and one mechanic said it is the headgasket leaking oil, luckily I didn't do it, I would of been out of 1000 bucks or so, and still would of leaked.
I had a similar problem on a D16. Even after replacing the distributor o-ring I still had a leak. What I did was put a bead of 3M silicon paste (or Hondabond) along the base of the distributor where it meets the block. Then reinstalled the distributor.Cured the leak.
I can see the oil come straight down from where the dizzy meets the head. I have done the vtec switch gasket and I know its not leaking. There are no other leaks on the whole engine, so I can get it pretty clean and see clearly where the oil is coming from. Its most likely the dizzy, I just wanted to get some more confirmation before I spent the money on a new one.
alecmesa96
Jun 18, 2023 04:48 PM
project93hatch
Jun 3, 2010 09:28 AM
gkitf16
Aug 16, 2005 10:01 PM
