Integra gsr no power
Old Oct 14, 2011 | 10:48 AM
MurtazaDSM's Avatar
Default Integra gsr no power
Recently my integra has not been getting power in first or second gear. The problem seems to happen after driving for a little bit and only if I come to a stop. If I come to a stop after the car warms up when I accelerate the car bogs really bad and hesitates like something is holding it back I can push the throttle all the way and the car will only go 5mph and this only happens it 1st and 2nd then the car just gets a surge of power and drives normal. I am throwing codes P0135 p0301 p0302 p1300 p1399. I changed my spark plugs,wires and distributor and still does the same thing. I also cleaned the iacv
Old Oct 14, 2011 | 11:52 AM
mouab18c1's Avatar
Default Re: Integra gsr no power
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P1300 Random Misfire
Have you checked your timing?
Old Oct 14, 2011 | 06:21 PM
fcm's Avatar
fcm
Old Fart
Ditto the above, check both the valve and ign. timing.
I would also check the ECT sensor, you may be running rich.
Random misfires are almost always due to a fuel issue, when was the last time you changed the fuel filter, have you checked to see what the fuel pressure is yet?
Check the PGM-FI Main Relay...
http://www.tegger.com/hondafaq/mainrelay.html
http://techauto.awardspace.com/mainrelay.html
Fairly common problem on older Honda/Acura.94
Old Oct 15, 2011 | 02:38 PM
MurtazaDSM's Avatar
I will check the timing on Monday since I'm not driving the car and I have never changed the fuel filter so I will try that also thanks I will update on the progress
Old Oct 16, 2011 | 06:37 AM
Dogginator's Avatar
Daisy... Daisy...
Check the valve adjustment as well.
Old Oct 18, 2011 | 12:12 PM
MurtazaDSM's Avatar
checked the timing and it was good I heard some noises coming from the distributor so I removed the cap and there was dust and oil in there. I had warranty so I got a new distributor and everything is ok for now
Old Oct 18, 2011 | 12:58 PM
MurtazaDSM's Avatar
New dizzy is also making noises I haven't adjusted it with the timing light yet but I don't think that would cause the dizzy to make noises or would it
hmtcrxsir
Mar 14, 2011 03:58 PM
bradennicely
Nov 19, 2009 02:50 PM
turbotegrar
May 20, 2004 04:13 AM
frogscivic
Jan 17, 2004 06:14 PM
User 5426
Jan 2, 2004 03:54 PM
