b20 vtec wont gain rpms
Old Oct 13, 2011 | 06:55 PM
striker5661's Avatar
Icon6 b20 vtec wont gain rpms
I have 90 integra with a b20 vtec i had it running great but had to get rid of my ecu and dizzy long story anyway i parked the car for about a month while getting cash to chip another computer and get a dizzy finally got it put it all back together now the car will start and idle perfect at 800-1000 rpms but when i step on the gas the rpms build extremely slowly like trying to start moving in 5th gear i have tested the ecu on other cars it works have tried other ecus on my car still dose samething checked all wires and fix anything that even looked like a problem checked fuel pressure thats good checked timeing its good checked tps works im not sure where else to look it dosent throw any codes any input would be appreciated thanks
Old Oct 13, 2011 | 08:06 PM
sebTeggy's Avatar
Default Re: b20 vtec wont gain rpms
Did you check your timing when you put your distributor back on? I swear to god if you advanced it all the way and end up blowing your motor, you will learn a lesson......
And by timing I mean your distributor angle. If you loosen the 3 bolts holding it, you can either tilt it forward or backwards.... You need to make sure its at the right spot.
Old Oct 13, 2011 | 08:59 PM
mouab18c1's Avatar
^ You mean ignition timing?
OP will need a timing gun to set that. Look it up on youtube for a DIY!
Old Oct 13, 2011 | 10:35 PM
sebTeggy's Avatar
Of course I mean ignition timing, confusion?
Old Oct 13, 2011 | 11:23 PM
mouab18c1's Avatar
Then make it clear when explaining it to someone else.
xlusiveracer
Apr 2, 2018 03:55 PM
B20vCRX
Nov 22, 2012 02:44 PM
baggedeg
Jun 10, 2011 09:23 PM
ef9_civic_hatch
May 23, 2007 02:13 PM
