hondata s200 cuts off at 4,000 rpm. need help
Old Oct 13, 2011 | 04:15 PM
PilotOnDubs's Avatar
Default hondata s200 cuts off at 4,000 rpm. need help
so i finally have the chance to get my car tuned today; but have an issue w/ it cutting out at 4,000 rpm.
my set up is as follows;
94 jdm h22a with i/h/e
omni power 70mm tb w/ port matched plenum
my tuner plugs in my p28 w/ my s200; wasnt able to communicate w/ it on his laptop at 1st.
plugs his p28 w/ his s200 set up in, and was able to communicate.
starts tuning it, but it starts cutting off at 4,000 rpm. like a rev limiter.
disconnects his set up; plugs my set up in and at this time it communicates and he does what he has to do, change the mapping and such to run right with my setup. car runs like a champ. and even puts out higher hp and tq.
we go on a road test, and still running like a champ. all done tuning at this point.
car sits for maybe 30 mins. as im just hanging out and then i leave the shop. as im driving, it starts acting up again; cutting off at 4,000 rpm.
i turn around and go back to my tuner and he thinks that both mine and his p28 have poor solder connections. suggested me to drive it in the morning when its cold. and see what happens.
strange how both p28's are cutting off @ 4,000 rpm
but at one point, my p28 was running fine w/o any problems
anyone ever have this issue? please help. thanx
Old Oct 13, 2011 | 09:04 PM
mouab18c1's Avatar
Default Re: hondata s200 cuts off at 4,000 rpm. need help
Did your tuner try a different map?
Old Oct 13, 2011 | 09:40 PM
no, dont believe he tried a different map.
weird how it did run w/o any issues on the dyno and then after on the road test.
Old Oct 14, 2011 | 09:03 AM
jonesEK's Avatar
ttt for answers
Old Oct 14, 2011 | 12:28 PM
mouab18c1's Avatar
Sounds like an electrical issue
Old Oct 14, 2011 | 02:11 PM
civic nation's Avatar
x2 ^ maybe somethings up with your o2
Old Oct 14, 2011 | 03:52 PM
SpeedwayCoating's Avatar
You have some sort of wiring issue somewhere if I had to guess. I doubt you had two computers with the exact same problem.
Old Oct 15, 2011 | 09:20 PM
spoke w/ a friend and he had a chance to take a look at my setup. opened up both sides of the ecu covers to inspect and had a feeling that the soldering on the rom socket was poorly done. he cleaned up the points and had me re-install it. worked like a charm. drove around all day today and havent had any issues so far. thanx h-t for all the support and help.
Old Apr 3, 2012 | 02:56 PM
bump. problem came back after five and a half months.
i think i need to replace the p28
Old Apr 5, 2012 | 08:34 AM
7rrivera7's Avatar
PM me...
Old Apr 5, 2012 | 11:10 PM
^ thanx, but i just purchased a replacement p28 sockected for s200 today. everythings working fine
twophastprelude
12
Mar 21, 2008 02:56 PM
Si Jeff
Jan 19, 2006 10:23 AM
Quick99Si
Sep 11, 2004 11:55 PM
neumonik
Jul 23, 2002 10:23 PM
