b18b head on b20b block
Old Oct 13, 2011 | 04:02 PM
Jillianbowman87's Avatar
Default b18b head on b20b block
How much of a difference is the b18b on a b20b?
Old Oct 13, 2011 | 04:04 PM
92lxsleeper's Avatar
Default Re: b18b head on b20b block
absoulty none. its the same head
Old Oct 13, 2011 | 04:23 PM
Dioxine's Avatar
should i think all non vtec b sieres heads are the same. I would make sure though
Old Oct 13, 2011 | 04:27 PM
b18b and b20b have the same head casting.
Old Oct 13, 2011 | 05:54 PM
fallrivercolin's Avatar
You are wrong. The b18b cams are the best of the 4 non vtec cams, and the b20z has bigger (vtec sized) intake valves. It is the best non vtec head. Im not positive if all b20z heads are like that though. You're best OE setup, from what ive heard, is b18b cams in a b20z head, on a b20z bottom end.
Old Oct 13, 2011 | 06:34 PM
98civdx's Avatar
Master Detailer
The vtec sized valves are the in the P8R spec head.
Old Oct 14, 2011 | 04:51 AM
Thank you for clarifying that. I wasn't quite sure which head exactly it was.
Old Oct 14, 2011 | 06:47 AM
I never said anything about a b20z. He asked the difference between a b18b and a b20b.
Old Oct 14, 2011 | 09:07 AM
B20BP8R's Avatar
Find a P8R head for your b20b. Or go here and peep this info https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b20-non-vtec-faq-guide-including-p8r-head-information-1467903/
Old Oct 15, 2011 | 07:27 AM
And nobody questioned what you said. I just offered the OP some advice on a better head to pick.
Old Oct 15, 2011 | 08:30 AM
EsotericImage's Avatar
Retired Moderator
+1 with the P8R head.. flows much better then the P75 castings.
Old Oct 15, 2011 | 03:03 PM
I really don't have the money to be changing head or block right now, just got into honda so Im learning as I go although I know part trading is easier with them. I just dont have a lot of choices around where I live.
Old Oct 16, 2011 | 01:33 PM
B20BP8R's Avatar
do your research man, good deal to start out now . It took me about two years to pick my motor. For the money B20Bs are the way to go.
Old Oct 16, 2011 | 02:28 PM
NotAJDMFanBoy's Avatar
Just save your money and keep it stock for now. You won't gain a lot from swapping parts without tuning.
GSR or B20Z would be my choice if you're staying B series, or get an H2B kit and drop an H22 in.
Old Oct 17, 2011 | 02:47 AM
Dioxine's Avatar
I was referring the the casting, as in the head gasket would work. Thanks for the advice though i did not know that.
Old Oct 17, 2011 | 04:35 AM
Ahh. In that case, you will want the b20 head gasket, as the block has an 84mm bore, as opposed to the 81mm more of the b18
Old Oct 17, 2011 | 01:24 PM
Well my block is a b20b and my head are b18. All I have is a leaking cam seal but I bought a complete gasket kit and gonna replace everything. The motor I have has alot of aftermarket parts on it. Its a 97 CR-V. My body is a 95 civic ex.
kennybintegra
Aug 27, 2006 09:11 PM
bambam
Apr 6, 2004 08:54 AM
97SactoLS
Sep 30, 2002 07:29 AM
fuguman
Sep 16, 2002 12:38 PM
