Just purchased a machine, issues.
Hi all, I had just graduated from HIWT and i bought a TIG machine to make some manifolds and other automotive related stuff. I am not new to tig welding which makes this dilemma even more annoying. I bought a Diversion 180, comes with a Weldcraft LS17 torch air cooled, 3/32 2% ceriated. 3/32 collet and collet body, and a 7 cup. I am welding thin stainless (under 2mm) with about 15CFH of gas. For some reason every single weld comes out to be gray and too hot. Only welding about 30 amps. And my tungsten is also turning a black/blue. I know for a fact that it has to be a gas delivery issue and turning the gas up isnt a fix, or a fix i will settle for. I am going to go get a bigger cup but that shouldnt be the only fix. Any input? thanks!
the post flow is working for sure, about 10 seconds of postflow.
UPDATE:
just put on a #12 gas lens, coverage and color is a little better, using about 20CFH. still isnt shielding properly. All lines are tight and used teflon tape. Im stumped
moving too slow? post some pics?
can you feel gas coming out? what's your post flow? Using pure Argon?
If nothing else works exchange your cylinder, might be bad gas or mix
shawnhayes
14
Jul 16, 2002 03:38 PM
