D16z6 leaking oil but not coolant
Old Oct 12, 2011 | 07:57 AM
CivicxTree754's Avatar
Photogenic
Loved
Icon3 D16z6 leaking oil but not coolant
I had the z6 head on the stock motor for about 4k miles until i got water in it and blew the bottom end. So i put the z6 head back on the orignal block ( it was sitting at my house ) and put it in my car. I noticed oil seeping out from where the head and block meet. It was at the exhuast side at the corner of the engine. I tightned the head bolts to spec and it slowed down alot. I tightened them a little bit beyond and it went away ( to the naked eye) but im still getting oil in that area all over the front of the motor, down between the engine/tranny, and all over the oil pan. I got out the dye and a UV light to trace it and its still coming from that area. Im not leaking any coolant though or seeing any oil in my coolant reservior. The head gasket was the single peice of metal from the head kit to lower compression a tiny bit as what ive seen from multiple threads around here. Is there any specific spot on the block that could let oil get out but not coolant as well? I dont understand how im leaking oil at the head area but not loosing any coolant...Any help will be appreciated. Im gonna try to get some photos tonight.
Old Oct 12, 2011 | 08:28 AM
92lxsleeper's Avatar
Default Re: D16z6 leaking oil but not coolant
Take it back off. Clean the mating surfaces, use a new headgasket and cover it in copper spray
Old Oct 12, 2011 | 09:06 AM
motegicivic's Avatar
Yes, you can just leak oil out of a headgasket and not coolant. By the way this the front of the engine, in header area?
How much oil are you losing?
Old Oct 13, 2011 | 06:00 AM
Photogenic
Loved
This is the best pic I could get. Im getting a decent drip all the way down to the oil pan and leaving small puddles. Its also leaking beneath the dizzy. So my leak extends from the front to the side smh.
I will def. have to look into the copper spray. I saw some other threads where guys have had stuff on the gasket surface.Thanks for the tips.
Old Oct 13, 2011 | 10:28 AM
Do you have reg pic, like daytime?
keslerbuilt
Dec 29, 2013 12:24 AM
andypwnz
Feb 19, 2013 03:40 PM
jaysalti
Apr 16, 2011 01:16 PM
lakerschamp2000
Apr 20, 2009 10:51 AM
Halo
Aug 12, 2002 06:27 PM
