Pop trunk prolemsss..cant figure out.. help!
sup fellas, i have pop trunk dilemma..i installed the solenoid and everything it works great..i tested in by letting the + solenoid wire touch the car battery and it pops.. but when i hook up the wire to the AUX on the alarm brain and press the option button the trunk wont pop..the remote is already programed for the AUX to work..could it be that i need a relay or some sort??? or is there some other way to solve this?
if you hooked the + wire that you touched to the battery to make it pop directly to the alarm it wont work because the alarm will put out a negative signal. you will need to add a relay and you will be good to go.
Which BTW is the reason they output a negative signal. The channel is only rated for 200ma and you'd blow it if it was directly driving the load. Bosch style relay wired as folows:
85 - alarm
86 - fused 12v
30 - fused 12v (same as above is fine)
87 - To solenoid
85 - alarm
86 - fused 12v
87 - To solenoid
Well any car stereo place Tweeter Best Buy,Circuit,Dows,Sound Advice,HiFiBUYs,Freemans,Cartoys...etc look to spend 5-15 bucks depending onif it has a harness or not...ask nicely you may be suprised you may get one tossed your way for free
85 - alarm
86 - fused 12v
87 - To solenoid
85 - alarm
86 - fused 12v
87 - To solenoid
Se-rv-Tak
Audio / Security / Video
Jan 22, 2004 09:18 AM
