Grounding point...
Old Oct 10, 2011 | 12:45 PM
jamzx3's Avatar
Default Grounding point...
Been having starting problems with my crx...can i get places where there should be grounds and pics to go with it...trying to knock possible problems off the list... thank you
Old Oct 10, 2011 | 12:55 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Grounding point...
Sounds like a backwards approach.
Might as well replace the brake lights and seats so you can check them off the list as well.
How about some detail about your car and the problem you are experiencing.
Old Oct 10, 2011 | 12:59 PM
jamzx3's Avatar
well, my problem is that car only starts when starter is bridged...changed out main relay and clutch safety switch...making sure all grounds are where they are supposed to be...bought an si that someone had swapped a d15b2 w mpfi
Old Oct 10, 2011 | 01:08 PM
lunalink's Avatar
Old Oct 10, 2011 | 01:15 PM
jamzx3's Avatar
that passenger front one ground...where on the engine does it connect to? crx has a battery there...must be a pic of an eg/ek
Old Oct 10, 2011 | 01:16 PM
4drEF's Avatar
Keyboard Humorist
so...... why did you change out the clutch switch and main relay?
Were they diagnosed as faulty?
Since you can bridge the ignition switch wire and get the starter to crank, the main battery power and ground are obviously good.
Since you replaced the main relay and clutch switch, there isn't much left.
Wires and ignition switch.
Try troubleshooting the ignition switch wire and work backwards.
Old Oct 10, 2011 | 01:19 PM
jamzx3's Avatar
thanx 4dref...ignition that came on the car is not from the correct civic...will change all that next
Old Oct 10, 2011 | 01:28 PM
4drEF's Avatar
Keyboard Humorist
... or just maybe save some time and get a test light the check the wire before going through the hassle of changing a part that might be perfectly fine.
What if you have a bad wire????
Old Oct 10, 2011 | 01:41 PM
lunalink's Avatar
thats mounted on your tranny to your chassis
its an EK but its all the same
Old Oct 10, 2011 | 01:49 PM
jamzx3's Avatar
yes, i do need to get a test list or multimeter...planning on changing it out anyway...the tumbler unit and casing are from a different car...has 2 wires that were clipped when the civics didn't have the 2 wires....thought i had a pic of it on mu comp...but it was only on my phone
thanx luna link...gotta check to see if there is a ground on the trans
Old Oct 10, 2011 | 02:09 PM
jamzx3's Avatar
heres a pic of the ignition lock and casing....
heres one of the stamping on the casing...
my accord one has sv4 so i know it belongs there...this one has k74...don't know what that is
Black R
Apr 8, 2023 07:14 AM
Keino1
May 18, 2015 10:01 AM
tauniFLA
Jun 21, 2012 05:44 AM
eaterofsmoke
Oct 7, 2009 07:27 AM
bywaters
16
Jan 14, 2009 05:04 PM
