Fuel Send unit??
Old Oct 9, 2011 | 04:45 PM
BobbyRodriguez's Avatar
Default Fuel Send unit??
I replaced my fuel pump, and i now need help with a replacement of my fuel sending unit or full gauge cluster.
The pump will not turn on, some times after a couple min's the check engine light shuts off and the pump will turn on.
Help pls thanks
Old Oct 9, 2011 | 05:01 PM
Former User's Avatar
Default Re: Fuel Send unit??
1) You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
2) You may have a main relay, ECU, or thermostat ground problem, though more information is needed. The fuel sending unit is only for the fuel gauge.
Old Oct 9, 2011 | 05:20 PM
all grounds are good.
Sry for the rules not being met i was in a hurry
but i just unplugged both flot and jumped it that was ok, but when i jumped the pump the check engine light did not turn off?? it should have right?
How can i jump the main to test which colors are for fuel?
Old Oct 9, 2011 | 05:24 PM
found the main relay wires jumping now
JdmR-ek
Aug 20, 2014 07:14 AM
Nonvtak monster
Aug 28, 2013 09:53 PM
ghettoda9
Apr 13, 2011 10:03 AM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
