Fuel Pump Problem
Old Aug 27, 2013 | 08:50 AM
Nonvtak monster's Avatar
Default Fuel Pump Problem
Hi everyone, i have a 94 integra and the fuel pump does not come on sometimes when trying to starting it. Sometimes it pressurizes but then stops and the car dies. Im for sure its something to do with the ignition switch for the key or the fuel pump cause it primes at times and sometimes doesn't. No check engine light but i did drive it the other day when installing new wheel studs and well i put my foot to the floor just to run it past 4k check engine light would turn on and off at times. Anyone have similar problems?? Could it be the main relay?
Old Aug 27, 2013 | 09:37 AM
B_Swapped93's Avatar
Default Re: Fuel Pump Problem
I would start with the main relay is the typical cause of problems like this. Unless your pump is old and starting to fail
Old Aug 27, 2013 | 10:43 AM
Okay is there a way i can test the main relay myself? the car does have 200xxx miles on it too so idk could be both. i unplugged the wires from the fuel pump this morning and found out that electricity isn't going through the wire when i turn the key to on position.
Old Aug 28, 2013 | 09:31 AM
tamboo's Avatar
10 Year Member
my original fuel pump was long gone before 200k.
some are close to $400 but you can get a brand x
unit for $25 or so at rockauto. or try http://car-part.com/
for cheap used parts. i got one from the latter to carry as a spare
after getting stranded the first time around.
http://autorepair.about.com/od/engin...nrelay_tst.htm
Old Aug 28, 2013 | 09:53 PM
I actually took off the main relay yesterday after doing some more research and forgot that eric the car guy on youtube made a video about it too. i soldered the cracked pin that was pointing out of the relay and bam starts right up every time now! Very satisfied now
ghettoda9
Apr 13, 2011 10:03 AM
JimmyM86
15
Oct 18, 2007 08:44 PM
juanchoenuncrx
Aug 29, 2007 07:59 AM
ROK801
Oct 31, 2005 07:28 AM
s.khang
15
Dec 16, 2003 01:46 PM
