Anyone know where this connect to?
im under the car, connecting all the wires together, this one righ here i cant figure out, i might be missing something but does anyone know where this connect to? its black and blue inside
It can't be knock sensor, because it's connector has only 1 wire.
Did you check service manual? There are all pinouts with wire colors in several pages somewhere... If you find, you can get connector number and then find the explanation in engine bay picture. I hope you understand, what I mean
I am used to 4gen manual, but 5gen should be very similar + many engine connectors are all the same in H22 motors.
Knock sensor should be a single wire, that does look more like the O2 sensor wire, and that's where it should be on a H22 harness, off the back of the block.
I've never used an H22 harness on an H22, I converted a B-series and an F-series in my cars.
i was thinkin the 02 sensor too but all of them connected already, this h22a4 was pulled out of a civic but when i pulled out my h22a4 out my car there was a wire attach to the engine on the bottom by like the water pump, i wonder if thats where it goes and if i need it, im still in the porcess of gettin this engine started up
I am used to 4gen manual, but 5gen should be very similar + many engine connectors are all the same in H22 motors.i was thinkin the 02 sensor too but all of them connected already, this h22a4 was pulled out of a civic but when i pulled out my h22a4 out my car there was a wire attach to the engine on the bottom by like the water pump, i wonder if thats where it goes and if i need it, im still in the porcess of gettin this engine started up
the wire that hooks up to iab solenoid on the bottom of the intake manifold should be a two wire connector. if that is a one wire connector it is the knock sensor. your oil pressure switch is right in that area too but your oil pressure light would stay on if it was it.
92 CiViC gsR
Apr 8, 2002 10:30 PM
