H22 civic cat-back??
i have a 94 h22 hatch with an egay header, for now... my question is will a civic cat back exhaust pipe be long enough to bolt up to the header?? the h22 header is longer than a d/b series so i thought maybe it could be as long as a stock exhaust mani and cat. therefore a civic cat back may mount up?? my exhaust is leaking bad from the crappy welds the muffler shops around here do. i would just like to buy a cat back exhaust. but want to make sure it will work before i pay for it. any help is appreciated. Thanks
I had to get a custom pipe welded from my H22 aftermarket manifold to my Apexi WS2 cat back as a standard "test pipe" or OE cat would not fit. The pipe I needed was about 11" long if I recall correctly.
You can always get one of those adjustable test pipes, adjust to where you need it, and just have the shop weld it together.
H22ACiViC
Jan 29, 2002 05:50 PM
