1998 Civic LX - AC Idler Pulley questions
Old Oct 7, 2011 | 01:46 PM
GSRpower's Avatar
Default 1998 Civic LX - AC Idler Pulley questions
Recently changed my water pump, which means I had to take all the drive belts off. After a few days, the nut that holds the AC idler pulley fell off while I was driving.
1) What size is this nut and thread type?
2) The link below shows a blow up of this assembly. When I put this back on I only had 3 pieces; the collar (far left piece that says "discard" on page 2), the idler pulley, and the nut. This blow shows several other pieces. Am I missing something which would probably be the reason the nut came off? As I noted above, I did not even have a washer behind the nut...not sure if that is correct.
http://www.tegger.com/hondafaq/tsb/civic/x00-003e.pdf
Old Oct 14, 2011 | 08:14 AM
GSRpower's Avatar
Default Re: 1998 Civic LX - AC Idler Pulley questions
Bueller?...Bueller? Anybody?
I got the nut that holds the pulley on, but still not sure if I'm missing a washer or anything else. TIA
zcmotor
Oct 1, 2013 08:15 PM
emooheo
Aug 12, 2011 11:30 PM
djoye
Sep 14, 2010 10:34 AM
redacura
May 26, 2008 03:57 PM
CKim
Mar 4, 2002 05:40 AM
