FS: Clean semi-built GSR head, headgasket, dizzy, harness, ecu
I have a very clean GSR head with 0 miles since machine work. The head was stripped down and "hot tanked", then assembled with Skunk2 dual springs and Ti retainers, brand new Honda valve seals, valves were freshened up, fresh 3 angle valvejob, fresh surface to an almost mirror-like finish, coated combustion chambers/exhaust runners, and then pressure tested. - $575
Head will only include:
Uncut Valvecover with all grommets/bolts
Water Neck, Vtec Solenoid and sensors
Also have obd1 GSR:
Dizzy with NGK wires - $100
Uncut Harness - $100
Virgin P72 ECU - $100
Brand new Honda Headgasket - $50
OBD1 GSR throttlebody - $40
OBD2 GSR throttlebody - $40
Painted wrinkle red valvecover - *SOLD*
Also have obd1 GSR:
