Gsr bearings in b16
Old Oct 6, 2011 | 11:49 PM
traxxasx's Avatar
Default Gsr bearings in b16
Would be safe to run one half of a gsr bearing along with one half of an b16 bearing in one Rod journal?
I know the gsr is much slimmer but still seats into place on the Rod cap. I ordered red bearings for my motor from Honda and they gave me gsr reds.
Old Oct 7, 2011 | 05:34 AM
kyden's Avatar
Default Re: Gsr bearings in b16
absolutely not.
Old Oct 8, 2011 | 01:02 AM
Built4Battle's Avatar
Originally Posted by kyden
absolutely not.
Why not
Old Oct 8, 2011 | 01:34 AM
traxxasx's Avatar
Ya, could you please explain, i searched the whole web, not one thing on it.
Ive taking apart a few gsr's and they had, acl std bearings in them. Not slim ones like oem. They were the normal width ones. I dont see why they cant be vise versa, if acls, or any other aftermarket will fit a gsr, and b16 ect..??
Old Oct 9, 2011 | 06:28 PM
streetplayas's Avatar
b16 rods are like ls gsr are way smaller you will have too much of a gap and you will get low oil pressure and youll spin a bearing thus messing up the crank
Old Oct 10, 2011 | 12:13 AM
traxxasx's Avatar
im using the b16 rods. im only using 1 gsr half bearing, all clearances are .0015 so its all good on the oil pressure. i dont know what your trying to say..
Old Oct 10, 2011 | 07:27 AM
kyden's Avatar
your side clearance is what lubricates the cylinder wall. gsr bearings are skinnier which = oil not spraying out correctly.
Old Oct 10, 2011 | 07:40 AM
exactly sorry didnt mean oil clearance issue i was speaking about a side to side clearance issue. The oil clearance is good though i woudn't recomend it but its actaully your motor but is it really worth taking a chance for 30 to 40 dollars your best bet is to order another set of bearings and play it safe cause itll cost you more in the long run
Old Oct 11, 2011 | 12:04 AM
traxxasx's Avatar
I see. Now that i did not know, i though the cylinder walls were oiled by the piston, oil ring land, it has tiny holes around it.??
Also if the slimmer bearings are sufficient for a gsr motor, why wouldn't it be for a b16? It is only 1 half, i dont think it would be too drastic?? Also oil squirters? Also here is the weird part, the acl standard box says for a b16, b18a b18b, ect.. and also a B18c...Now these are fat acls, why would larger acls work for a gsr but not vise versa?
Old Oct 11, 2011 | 04:58 AM
kyden's Avatar
i'm looking at the acl catalog now, and they have different part numbers for the rod bearings between motors. b series mains are all the same though.
there's no way it would work as it sits anyway, since the tangs on the gsr rod bearings are on the wrong side.
GuiVtec
May 22, 2010 05:10 AM
96 GSR-T
Mar 16, 2008 06:05 AM
jakscivic
30
Jan 3, 2008 01:18 PM
Race Egr
Sep 30, 2004 09:36 PM
Neukin
Aug 6, 2003 04:28 AM
