Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
can't get brake dust boot bin properly
Old Oct 6, 2011 | 12:46 PM
dk127's Avatar
Default can't get brake dust boot bin properly
I got the driver's side on fine, but on the passenger side when I compress the piston with a c clamp and old pad I can't get the boot in right; it keeps puffing out. I've never actually had this be an issue before. Any suggestions?
Old Oct 6, 2011 | 02:56 PM
redbull-1's Avatar
Default Re: can't get brake dust boot bin properly
Got a picture?
Generally, as long as the rubber piston boot doesn't get pinched it won't be a problem. On some Toyotas, they puff out like nothing you normally see on a Honda.
Old Oct 7, 2011 | 05:42 AM
bee guz's Avatar
If the boot isn't fitting there is rust or something you missed in that grove, take it apart and get a small straight screwdriver and run it around the grove to feel if there is a rust bump you missed.
Scrape that grove as good as you can, then the boot will fit, I have had that problem hundreds of times.
bigsnorlax
Dec 13, 2010 09:22 AM
ROOROWNS
Jun 2, 2005 08:55 PM
rasinhell
Mar 7, 2005 06:09 AM
ACURA dreamin
Mar 11, 2004 11:52 AM
