SRR SOHC Flywheel
Old Oct 5, 2002 | 12:42 PM
inspyral's Avatar
Default SRR SOHC Flywheel
I'm thinking of picking up this SRR flywheel for a couple reasons:
1) it's chromoly
2) it's 11lbs, not too light
3) it's several hundred dollars cheaper than the Zex SOHC chromoly flywheel
I have a couple conerns, though. For one thing, it doesn't seem to have the dowel pins that the stock and other flywheels have for lining up the clutch cover. Should this deter me from making this purchase, or is it not a big deal? Since all the other flywheels I've seen have had the dowel pins in them, I assume they're there for a reason. Also, this pic seems to differ from the pic on the official SRR website, so I'm wondering if it's a real SRR flywheel. Here is the pic from the SRR site:
Anyone have any insights?
Old Oct 5, 2002 | 05:23 PM
IN VTEC's Avatar
Default Re: SRR SOHC Flywheel (inspyral)
Well, how many flywheel bolts are there on a D-series crank?
The bottom pic looks like a B-series flywheel with 8 bolt holes.
The pic that I have of the SRR SOHC flywheel also has 6 holes, like the top pic.
BTW, if you're price shopping, I can do $280 shipped....providing that they have them in stock.
Old Oct 5, 2002 | 08:10 PM
ninesecrx's Avatar
Default Re: SRR SOHC Flywheel (IN VTEC)
Those look different for 2 reasons. The pic on top is for a sohc and the bottom pic is of a dohc. The other reason they look different is because the pic on the bottom is the top of the flywheel where the clutch bolts up to and the pic on the top is the bottom of the flywheel. I see dowel pins in the pic of the bottom so it should come with them. You cant see if they are in there on the top picture because its the wrong side, they would be on the other side....Mike
Old Oct 5, 2002 | 08:18 PM
D-Man's Avatar
What?!? how much is that SRR flywheel,$80 cause i paid $280 for my Zex Sohc flywheel directly from zex off thier web site like 6 months ago.
Old Oct 6, 2002 | 12:36 AM
ExospeedAMcrx's Avatar
Default Re: SRR SOHC Flywheel (D-Man)
i'll hook it up on a CM flywheel if you need it fast
Old Oct 6, 2002 | 01:04 AM
inspyral's Avatar
I didn't figure they would show a pic of the bottom.
I found the SRR for 200, and I think they usually go for around 280. The only prices I could find for the ZEX were around $450+
Old Oct 6, 2002 | 01:11 AM
ek44's Avatar
i tought that srr only makes flywheels for b16s.
but i could be wrong.
Old Oct 6, 2002 | 09:00 PM
IN VTEC's Avatar
Default Re: SRR SOHC Flywheel (ek44)
The only make flywheels and final drives for D-series engines.
Old Oct 6, 2002 | 09:02 PM
inspyral's Avatar
Looks like they make drivetrain parts for both the SOHC VTEC and the B series engines
http://www.srr.com.tw/eng-engine.htm
[Modified by inspyral, 10:03 PM 10/6/2002]
Old Oct 7, 2002 | 07:21 AM
IN VTEC's Avatar
I guess I'll have to talk to the distributor and see what other kinds of good stuff they'll agree to start stocking.
trooper0641
Apr 6, 2010 11:41 AM
jdm civic 2000
May 21, 2006 03:14 AM
sk8rmike
Mar 24, 2004 12:24 PM
inspyral
Oct 5, 2002 02:12 PM
