Interior car leak problems 90-93 integra
Old Oct 6, 2011 | 08:15 AM
NayborhoodJohnny's Avatar
Default Interior car leak problems 90-93 integra
It just poured in so cal these past few days...
i have had water leak into my trunk and water seep into the front area of the cabin.
i already changed the seals under the cover of my hood from the DIY in the forums.
my guess is the front windshield needs to be taken off and re-sealed.
i dont really know whats going on with the trunk.
i cant put anything in there because it just puddles up.
is anyone else having this issue with their 90-93 integra?
Old Oct 6, 2011 | 05:32 PM
fcm's Avatar
fcm
Old Fart
Default Re: Interior car leak problems 90-93 integra
Tail light gaskets, #4... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal assuming it's a hatch, the 4 door is diff.
The other problem may be the sun roof drain(s)... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal may have come disconnected at some point.
I would also check the pressure relief "vent", on the inner panel, just below the power ant., behind the rear inside quarter trim panel. 94
Old Oct 6, 2011 | 08:06 PM
lt1guy's Avatar
Antenna tail lights or trunk/hacth seal have a friend hose it down while your inside the car and see were its leaking.my 2cents
Old Oct 6, 2011 | 08:51 PM
DAman9's Avatar
sunroof drains i guarantee it, happened to me just seal it with some waterproof sealant.
one in trunk is behind the plastic covers on passenger side..(just look for the clear tube and follow it)
one in front is a pain, gotta go up behind a whole crap load of stuff on the passenger side.
just clean and seal them and your good
Old Oct 9, 2011 | 07:49 PM
ill try sitting in the car while it gets hosed down.
i dont have a sunroof, does this eliminate that sun roof drain fix?
what do you mean by antenna tail lights?
Old Oct 9, 2011 | 08:23 PM
fcm's Avatar
fcm
Old Fart
pretty much.
You will need to strip the interior to see where the leaks are, just sitting in the car with someone hosing it down is not going to work, all the leaks mentioned above are behind trim paneling.
Both the power ant. and the tail lights a common leak points on your car. 94
Old Oct 11, 2011 | 10:38 AM
lt1guy's Avatar
Just pull away the carpet panels look around the antenna for water and the taillights or the weather stripping around the hatch trunk that's how I found mine
Old Oct 12, 2011 | 02:46 PM
K20ek9hatch's Avatar
check the sunroof drain holes
Old Oct 13, 2011 | 12:57 PM
hatmanafro's Avatar
wow.. somebody didnt read.
but yeah man @OP change your tail light gaskets. that will fix most of that water seepege. for the front. make sure you did the diy right man.
Old Feb 14, 2014 | 06:53 AM
James Fillmore's Avatar
Wanted to introduce myself. Jim Fillmore, Detroit Muscle Technologies. We make body and heater box restoration gaskets for muscle cars; mostly old Mopars like Barracuda's and Charger. BUT we have had a bunch of requests from BMW, Honda, Mazda, etc guys for taillight gaskets to fix the exact same problem this post refers to. Seems like most of the auto manufacturers used/spec'd or were supplied gaskets made from very low quality materials. After a few years the gaskets take a set and are no longer resilient enough to do their job. We make premium gaskets for old cars from the most expensive, highest quality materials available. Even though the raw material costs have gone up double digits every year we refuse to use a lesser quality product. We currently make taillight gaskets for 93-97 and 98-01 3dr models. At this time I only have them listed in our Ebay store (search for DMT ACURA). Are there any other "trouble" taillight gaskets that need a better version of the OEM gaskets?
Thanks!
Logan Williams
Feb 9, 2016 07:08 AM
NayborhoodJohnny
Jan 19, 2012 04:38 PM
JDMx05
Sep 10, 2011 08:02 PM
Pandahatch93
Dec 16, 2006 07:11 PM
kikkoboyie
Jul 9, 2003 07:35 PM
