Interior car leak problems 90-93 integra
It just poured in so cal these past few days...
i have had water leak into my trunk and water seep into the front area of the cabin. i already changed the seals under the cover of my hood from the DIY in the forums. my guess is the front windshield needs to be taken off and re-sealed. i dont really know whats going on with the trunk. i cant put anything in there because it just puddles up. is anyone else having this issue with their 90-93 integra? |
Re: Interior car leak problems 90-93 integra
Tail light gaskets, #4... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal assuming it's a hatch, the 4 door is diff.
The other problem may be the sun roof drain(s)... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal may have come disconnected at some point. I would also check the pressure relief "vent", on the inner panel, just below the power ant., behind the rear inside quarter trim panel. 94 |
Antenna tail lights or trunk/hacth seal have a friend hose it down while your inside the car and see were its leaking.my 2cents
sunroof drains i guarantee it, happened to me just seal it with some waterproof sealant.
one in trunk is behind the plastic covers on passenger side..(just look for the clear tube and follow it) one in front is a pain, gotta go up behind a whole crap load of stuff on the passenger side. just clean and seal them and your good |
ill try sitting in the car while it gets hosed down.
i dont have a sunroof, does this eliminate that sun roof drain fix? what do you mean by antenna tail lights? |
Originally Posted by NayborhoodJohnny
(Post 46155991)
You will need to strip the interior to see where the leaks are, just sitting in the car with someone hosing it down is not going to work, all the leaks mentioned above are behind trim paneling. Both the power ant. and the tail lights a common leak points on your car. 94 |
Just pull away the carpet panels look around the antenna for water and the taillights or the weather stripping around the hatch trunk that's how I found mine
check the sunroof drain holes
Originally Posted by K20ek9hatch
(Post 46172818)
but yeah man @OP change your tail light gaskets. that will fix most of that water seepege. for the front. make sure you did the diy right man. |
Originally Posted by hatmanafro
(Post 46177731)
wow.. somebody didnt read.
but yeah man @OP change your tail light gaskets. that will fix most of that water seepege. for the front. make sure you did the diy right man. Thanks! |
