AEM fuel pressure regulator question
Old Oct 5, 2011 | 04:27 PM
bunkrd you's Avatar
Default AEM fuel pressure regulator question
I bought a fuel rail/intake manifold/throttle body combo and the fuel pressure regulator didn't come with any mounting hard ware however I know it is a bolt on. Is it possible to run this with just going down to the hardware store to get the proper mounting bolts or am i screwed?
http://cgi.ebay.com/ebaymotors/COMBO...#ht_4355wt_939
here is a sample of the the fuel rail and regulator.
Old Oct 5, 2011 | 06:18 PM
guessohw's Avatar
Default Re: AEM fuel pressure regulator question
You need to reword your question. Are you asking can you drive the car without the regulator on? I apologize if I missing something. As for the mounts bolts I believe those are 10mm which you can find anywhere and if you have a civic already then take yours off and use those because that's how the AEM kit comes. I too have that same setup.
meheartmycivic
Jul 20, 2009 01:45 PM
boostedgsr1234
Jul 8, 2007 09:31 PM
typertn
Jan 9, 2004 11:58 PM
DIRep972
Apr 4, 2002 09:27 PM
