k20 head questions
Old Oct 4, 2011 | 05:08 PM
lilrobie69's Avatar
Default k20 head questions
ok so guna biuild a k20/k24. im geting a k20 head out of a base rsx. i was wondering what valve train or mix of valve trane prts would be the best. jdm cams or euro. just getting into k motors iv always been d aone h and d motors.
Old Oct 4, 2011 | 05:36 PM
doood's Avatar
been there done that
Default Re: k20 head questions
You do not want a base k20 head
Old Oct 4, 2011 | 06:55 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
if you use a base head you are pretty much gonna be starting with nothing..
do yourself a favor and buy a type-s head.
BTW why do you want to build a frank? And if you are serious (no offense) then you should know the difference between a base head and type-s head for your k20/k24 frank.
What are your horsepower goals?
Going N/A or boost?
Why not just run a k24 longblock?
Do you just like the sound of k20/k20 frank... in the end it's still a k24.
Old Oct 5, 2011 | 09:13 AM
lilrobie69's Avatar
ok ik there is a diff between the two heads but im asking if its lik a b series where the valve train is the only diff bc ill buy used type s valve train somewhere. this is my firts time messing with k series. idc what the hp is this is. just finaly starting to explore k seiries. i got the head for stupid cheap and my buddy has the. k24 block
Old Oct 5, 2011 | 09:28 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
which K24 block.
If you swap out every component you can have true vtec in that head. (i believe)
Old Oct 5, 2011 | 11:00 AM
lilrobie69's Avatar
the Block is out of a 2006tsx i dont remeber the exact code. once again got it for stupid cheap. and thnk you now i will search for the valve train. and one more question shoud i use the type s ecu or a civc si?
Old Oct 5, 2011 | 01:20 PM
doood's Avatar
It's easier to just find a complete type s head instead of the entire valvetrain
You'll need kpro regardless so what ecu you use doesn't matter as long as it's from a manual car. If you're using a 6 speed tranny a prb is preferred because it has the reverse gear lockout.
Old Oct 7, 2011 | 02:38 PM
blah1219's Avatar
Get a k24a1 head. It's the best stock flowing head from production. They sale for cheap. I got one for 100 shipped with all valve train. You can buy k20a2 valve train for cheap. Type-s rocker assembly for like 50 and cams for 50-75. You can build a k20a2 head for under 400 and it will flow better. K20a2 heads go for like 600 and k20z1 for 750.
Use that rsx base head as a paper weight, that's about how good that head is worth.
Go explore k20a.org and ephatch.com, soak up all the information in because you are about to get into knees deep into k series.
As in ecu, you will need k-pro for sure. It's not worth risking that engine.
K series is nothing like b series at all. It's like comparing apples to oranges. You have lots to learn young grass hopper.
daymkimchee
Nov 2, 2010 05:04 PM
Mechman456
Oct 11, 2006 05:05 PM
Top Ramen
Acura TSX
14
Sep 23, 2004 05:35 PM
AlienKrOZ
Jul 22, 2004 05:28 AM
onePOINTsix
Dec 23, 2003 10:58 AM
