B18b cable trans sol swap alignment issue
Old Oct 4, 2011 | 01:46 PM
barrett_5's Avatar
Default B18b cable trans sol swap alignment issue
Question! i have an issue. you guys have been super helpful before.
i have :
Hasport B/vtec sol shift linkages
Hasport cable trans mount
Hasport 3 bolt mount
Si/SiR rear T mount
the engine is 1 - 2 inches too far forward.. so the linkage and rear T mount don't bolt up. suggestions anyone?
Old Oct 4, 2011 | 01:54 PM
grumblemarc's Avatar
The Grumpiest
Default Re: B18b cable trans sol swap alignment issue
Is that the correct rear mount?
Old Oct 4, 2011 | 01:59 PM
barrett_5's Avatar
from all the research i've done yep. on here and hondaswap both says that's the one i need. either way, i could reuse the LS T mount and it'd probably bolt up fine, but still wouldn't help the shift linkage situation
Old Oct 4, 2011 | 02:09 PM
98civdx's Avatar
Master Detailer
There could be 2 issues. T bracket, linkage.
is the hydro/cable linkage interchangeable?
Also, Are you using a "EK'' Si t bracket? If so, it wont work. You will need to use one from a integra. Also, do you know if the hydro/cable t brackets are interchangeable?
Old Oct 4, 2011 | 03:23 PM
barrett_5's Avatar
Yep they are interchangeable, hasport said the shift linkages are same for hydro/cable, yep I have a 99-00 so rear bracket. So I need to use my stock LS one? I read you were supposed to use the Si one? Why the difference? I've got pics too. Ill up load them in a minute (I'm using my phone)
Old Oct 4, 2011 | 03:36 PM
barrett_5's Avatar
[IMG]http: //i1213.photobucket.com/albums/cc476/tylerbarrett/93%20Del%20Sol/IMG_20111004_172008.jpg[/IMG]
Old Oct 4, 2011 | 04:12 PM
98civdx's Avatar
Master Detailer
thank you for clear photo's.
Unless the cable swap is different you are supposed to use the DC.
The Si bracket would be for 96-00's that are being B swapped.
Old Oct 4, 2011 | 04:20 PM
barrett_5's Avatar
No problem. Thanks for the help. Alright, new plan I guess. See if I can use the LS rear T mount and my buddy has a set of EF B series cable trans linkages we're gonna see if they fit. If not, ill get my stock ones cut and welded to fit and see if I can return the linkages I bought since they don't work.
Old Oct 4, 2011 | 04:28 PM
98civdx's Avatar
Master Detailer
I wouldn't do that just yet. Something is wrong here.
Whether it be the T bracket or, the actual engine mounts.
Old Oct 4, 2011 | 04:47 PM
barrett_5's Avatar
It can't be the mounts because hasport had to make them from scratch cuz they're had none in stock and I verified that they are the proper ones. Just Weird how its not working.
Old Oct 4, 2011 | 04:49 PM
98civdx's Avatar
Master Detailer
Did the mounts bolt in right? I mean easy. Hasport makes good ****.
When you try the new t bracket, do that first, and then try the others.
Old Oct 4, 2011 | 04:55 PM
barrett_5's Avatar
The mounts slid in perfect. No problems. The rear mount will help keep the engine stable but won't hop the positioning of It. So the linkages are still ****ed.
Old Oct 4, 2011 | 05:01 PM
98civdx's Avatar
Master Detailer
This is why I am thinking something is screwy with the mounts.
What I would do.
Remove the engine mounts, of course hold that sucker up with something.
Put the rear mount/DC t bracket in, and then try the engine mounts again.
I am fairly certain you'll the find the issue.
I am not knocking Hasport at all, **** happens, and something is not right in there.
Old Oct 4, 2011 | 05:11 PM
barrett_5's Avatar
I believe u are right about me having the wrong rear mount. I do believe that the mounts are correct tho. I think they company I got the linkages from either boxed the wrong ones or the fact that it is a cable trans not hydro throws off the length. Maybe these B series EF linkages will work. Trying them Thursday
CapnKrunch
Sep 1, 2010 07:19 AM
bap168
May 15, 2008 06:41 AM
1xfastxhatch
Aug 31, 2007 02:53 PM
WayFastWhitie
Dec 18, 2004 05:57 PM
