91civic rear disk conversion question
Old Oct 3, 2011 | 07:39 AM
skill178's Avatar
Default 91civic rear disk conversion question
i came across some rear disk brakes off a 89 integra and was wondering what all has to be changed on my 91 civic si to put them on there. some people say nothing, some say MC and some say MC and booster.
checked autozone and the boosters seem to be the same diffrent part number but same exact specs. anyone know if i can use my stock booster?
i need to change the MC anyways but i need to know if i should get integra's or civic's MC.
also do i need to change the p valve?
Old Oct 3, 2011 | 08:28 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 91civic rear disk conversion question
40/40 proportioning valve and a 15/16" Master Cylinder from a '90-91 Civic EX... Aside from the brakes themselves this is all you need. The master cylinder outlets are in the same location, angle, and size as your stock and will bolt right up to the stock brake booster. Same goes for the proportioning valve.
Old Oct 3, 2011 | 08:48 AM
skill178's Avatar
okay thanks, is there any other cars i can get this / p valve off of? just curious.
also, what will happen if i use the stock MC and valve? just untill i get this MC and valve?
if it does like my mustang did the back brakes wont work that great.
Old Oct 3, 2011 | 09:58 AM
wolf95's Avatar
will a 91 DA MC work? I'm thinking about converting all four hubs over to my 91 si.
Old Oct 3, 2011 | 10:24 AM
Todd00's Avatar
I said I don't want a title!
Just curious, but why are you doing the swap?
Old Oct 3, 2011 | 10:39 AM
wolf95's Avatar
cuz drum brakes are stupid
Old Oct 3, 2011 | 11:03 AM
asianflava's Avatar
89 parts won't work. The rear is totally different, it has a rear beam 4G Civics have independent rear suspension. You need something newer, 90 and up.
Old Oct 3, 2011 | 11:05 AM
DO IT ON ALL FOURS
That statement was ignorant... The Integra master cylinder would require a booster change...
OP - you are better off just waiting at that point. Your brakes would be extremely soft and potentially dangerous...
Old Oct 3, 2011 | 12:10 PM
skill178's Avatar
i wont actualy put the brakes on untill i get a MC and p valve that will work. just trying to find where all i can get the correct ones. friends have some parts and i check places like craigslist for junk honda's being parted out. was just thinking about my mustang has factory MC and a disk brake swap in the back. the back brakes dont work unless you pump the brakes repetedly but the front work fine and stop the car.
Old Oct 3, 2011 | 06:59 PM
zrickety's Avatar
pretty sure he's right. you want 90 up rear discs for it to work. 4040 proportioning valve and EX or DA master cylinder should be used also.
Old Oct 3, 2011 | 08:40 PM
///Mathew's Avatar
The way I did it, I went for DA Integra front and rear disc conversion, as well is DA proportioning valve, master cylinder and booster. Rather than having part A from one car, part B from a different car, the whole system is DA and designed to work together. And the brakes are fantastic.
Old Oct 4, 2011 | 06:02 AM
Todd00's Avatar
Yes, rear drums are stupid because they are lighter in weight and stop the car just as good as rear disks.
The EF forum never lets me down...
Old Oct 4, 2011 | 06:52 AM
skill178's Avatar
yea they will stop you just as good, when thatss all you have. get disks and see how much better you stop, exspecily after hittin some roads like dragons tail in tenn. lets see if your drum brakes even work after that.
Old Oct 4, 2011 | 07:03 AM
DO IT ON ALL FOURS
See now we are getting to a topic people have no clue what they are talking about... Being I'm in the upper echelon of "baby boomers", I must ask a question... If drum brakes are so horrible - why oh why, did they put them race cars, semi-trucks, and passenger vehicles let alone vehicles on all four corners? Why is it to this day they still put them on vehicles? There are advantages and disadvantages to both. You can't say the technology didn't exist either... Regardless, you must understand you are also putting bigger than stock brakes. This has been beat to death and you would be surprised by the results when tested side by side... take for example a CRX Si and a CRX DX...
Old Oct 4, 2011 | 09:12 AM
skill178's Avatar
im getting disks because my drums suck, riding curvy roads and such with hard braking i had to stop because my brakes got too hot and stopped working, disks im getting drilled and slotted rotors so hopefuly that wont happen again. plus disks look better
and disks come factory on most modern cars. exspecily sportiewr ones. drums only come on lower end cars like alot of the kia's (not all but lower end) and such cars. they are probably cheaper for the manufacter and at the same time provide sufficient braking for daily driving,
when it comes down to it, drums and disks work as good as the other, untill it gets HOT then disks cool faster and work better. thats the ONLY reasion im swapping. disks are more exspencive but ill manage the $10 more per brake change.
Old Oct 9, 2011 | 12:24 PM
wolf95's Avatar
The ONLY reason I said drum are stupid is because I hate working on them. I didn't mean to start a fuss.
Old Oct 9, 2011 | 04:38 PM
Zaakro's Avatar
This is correct. If you use a DA master cylinder you will have to change out the brake booster as well. The bolt pattern is not the same. You will also need the brake cable and brake lines from a DA. You can get the brake lines from a CRX Si if you want as well.
Mr. Winky
Suspension & Brakes
Jul 17, 2011 07:24 PM
949
31
Oct 7, 2009 11:17 PM
eskerley
Jan 23, 2008 03:24 PM
Bnjmn
10
Dec 8, 2002 03:08 PM
