gsr crx, ran great then changed motor now has bad miss fire
Old Oct 2, 2011 | 04:12 PM
nicefighter80's Avatar
Default gsr crx, ran great then changed motor now has bad miss fire
I have a 1991 crx si, it had a obd2 gsr in it, it ran great and drove fine. Well one night it blew up, so I got a replacement engine (obd1 gsr) , hooked everything up and swapped it in, now runs like it has a huge miss fire and has code 22 and 5, vtec pressure and map, I don't see why it could be the map, it worked fine on the old engine. Any ideas on where to start looking? changed wires, timing is all good too
Old Oct 2, 2011 | 04:16 PM
crx_si-r's Avatar
Default Re: gsr crx, ran great then changed motor now has bad miss fire
is the MAP sensor firewall mounted or throttle body mounted? its possible the vtec pressure switch is bad on the new motor. try swapping in your old one.
Old Oct 2, 2011 | 04:30 PM
It's a TB mounted map and the new vtec solenoid doesnt have the spot for the vtec pressure switch so its just unplugged
Old Oct 2, 2011 | 04:43 PM
crx_si-r's Avatar
thats why your CEL is on for you vtec oil pressure switch. all you have to do is splice the pressure switch wire (stock color is blue/black on engine side) to the vtec solenoid. this will bypass the oil pressure switch.
Old Oct 2, 2011 | 04:53 PM
Thanks I'll try that, but i need to fix the idle, ill post a video, but its running rich, shooting flames even
Old Oct 2, 2011 | 04:54 PM
then after it runs for 30s the idle climbs very high and i shut it off before it get to high
likwidchz
Engine Management and Tuning
Jan 21, 2013 07:48 AM
1SikEagle
Apr 11, 2009 01:02 PM
Sil84
Jun 14, 2008 08:59 PM
roadracer321
Jun 7, 2006 07:48 PM
iNERtIA
Apr 3, 2006 09:42 PM
